ArcEngine - Page Layout Control
2760
10-19-2015 07:08 AM
MichaelRutkowski
Is the use of the page layout control is not available with a ArcGIS Desktop license. It seems a little odd that we'd have access to the map control, TOC, toolbar, etc, from a ArcGIS Desktop license, but not the Page Layout.
I am starting off my application with a form which contains a map control (We'll name this the Map Form). From the map form, I have a menu option to print, which will open up another form with the Pagelayout control (we'll name this the print form). When the print form opens up, I get a licensing error.
Attached is an example application to show my troubles. The new 'print' dialog is opened from the file menu of the main ('map') form.
MichaelRutkowski
I only get the licensing error when moving to a production environment which does not have ArcEngine installed. I added an installshield project to help facilitate deployment and testing. You'll probably have to muck with some of the file location settings to get it to build.
