Making a Group Map
7125
10-15-2015 07:59 AM
CharlieFitzpatrick
Esri Alum
Many educators ask how to make a map as a group. There are several strategies for this.
  1. The simplest method, which I recommend for people who are just starting, is to use map notes, which can be done even with just a public account. A document by the Geoporter group explains the process (English: http://bit.ly/MakeAGroupMap_AGO; Spanish: http://bit.ly/HagaUnMapaGrupal_AGO).
  2. Another method is to publish a CSV into an Org as a feature service, push it into a map, and have people access either the map or (better) a web app (such as a GeoForm) in which they add their own content. This is simple and can be a little more elegant because it's all in one service, and can have attachments, but the CSV cannot constrain the type of content entered. This route requires an Org for the service, and the creator can decide if contributors must belong to the Org and sign in, or any Org and sign in, or have any AGO account and sign in, or not sign in at all.
  3. A more robust version of #2 is to use a feature service published via the publishing service at http://developers.arcgis.com (accessible only if/when you are logged into an Org with publishing credentials). This lets you define the field types (text, number, etc) but not constrain a field to specific choices. See the graphic below to know what to look for on that page: developers.jpg
  4. A more robust version of #3 is to use a feature service published via ArcMap with domains established. There is an "older" blog and map that describes this (http://esriurl.com/funwithgis128) and a wonderful recent course on the Esri Virtual Campus that walks users thru this process (http://esriurl.com/vcteachingwithgis2).
  5. The next step up is to work with some of the various field data collection apps that Esri has made available. See http://esriurl.com/k12gis and go to "06.Apps&Programming". [[See Survey123 notes added below.]]
As with much of GIS, especially online GIS, there are multiple ways to accomplish an important task. Again, for novices, I recommend starting with Route#1 above, because it is doable, fast, with minimal knowledge, and will lead users to discover the value of learning the more powerful methods if they want more standardized content and broader participation.
CharlieFitzpatrick
Esri Alum
Please comment here if you have tried one of these routes. Success or failure, we want to know what you've tried!
CharlieFitzpatrick
Esri Alum
Check out the blogpost http://esriurl.com/funwithgis191 and GeoNet thread Survey123 sample activity (especially for schools) to learn about Survey123 as a great way to do this in a group with mobile devices.
CharlieFitzpatrick
Esri Alum
Check out Survey123 at http://survey123.arcgis.com. ArcGIS Online users with publishing privileges who have logged into their Org account create highly customized survey forms just with a web browser! It's not quite as powerful and flexible as the spreadsheet method, but it's very easy, with a click-and-drag set of capacities.
