Default Text Field
1651
10-14-2015 11:01 AM
RonKnepper
Ok this seems like it should be simple, how do you define a default text field?  I tried just using quotes and then not but either way the default text I want to show isn't being displayed.  I have a field for TYPE which right now only has one option until we expand so I want to just default the text to the only option
IsmaelChivite
Esri Notable Contributor
If your question type is text, you do not need quotes. See screenshot below.
If your question type is a select_one, then make sure the default value is set to the value in your choices list, rather than the label.
RonKnepper
Thanks, I though I did that and didn't get any data come through.  I recheck.
