Error using insert cursor (da) with featureclass in a geometric network
3435
8
10-13-2015 12:46 PM
CallumSmith
New Contributor III
Hi
I am got an issue where I am trying to insert features into a feature class that participates in a geometric network.
Firstly I guess the question is "Is this even possible?"
When I try to insert a record into the featureclass I am getting this error: SystemError('error return without exception set',)
If I remove the geometric network or use the code on another feature class that does not participate in a geometric network it works fine. I cannot however remove the geometric network from the production database.
If anybody has any ideas on this issue that would be appreciated.
cheers
Callum
DanPatterson_Retired
From here...
This statement
The following includes some dataset types that can only be edited within an edit session:
  • Feature classes participating in a topology
  • Feature classes participating in a geometric network
  • Versioned datasets in enterprise geodatabases
  • Some object and feature classes with class extensions
But I have not clue if it applies to your situation.
NeilAyres
Recently completed a tool to update / insert into a Network Dataset. I can confirm that you need a edit session open.
Good to know...I wish you could make notes in the margins of the online help
CallumSmith
New Contributor III
Thanks Neil
I do have an edit session open as the featureclass is also in a versioned enterprise geodatabase.
In my testing I have copied the data to a file gdb and it still does not work. If I remove the geometric network the it does work???
cheers
Callum
CallumSmith
New Contributor III
Thanks Dan
Yes I do have an edit session open as the featureclass participates in a geometric network and is also versioned.
Not sure why it is failing as the error message is not very helpful!!
cheers
Callum
ModyBuchbinder
Hi
I did not tried it but you can start edit in ArcMap and run your script in the python window.
Maybe it will work...
Have Fun
CallumSmith
New Contributor III
Yes I have tried running the script from a tool within arcmap and it still gives me the same issue.
cheers
Callum
JohnPlunkett
As Callum pointed out to me in a separate email it looks like its a bug.
Bug NIM-102778
Synopsis
The insertRow method of arcpy.da.InsertCursor fails when working with data in a geometric network.
Additional Information
N/A
Alternate Solution
The Append tool works fine for features participating in a geometric network.
1. Fill an empty feature class outside the geometric network with records using an insert cursor.
2. Use the Append tool to add the records to the feature class in the geometric network.
http://support.esri.com/en/bugs/nimbus/TklNMTAyNzc4
