Calculate Field
2725
10-13-2015 05:43 AM
JenTaylor1
I am trying to get the count of forest cover that is greater than 200 feet along a line. I am wondering if there is a way to do this with the calculate field in data management and if so how. Thank you in advance for any help!
TimWitt2
Jen,
use "Select by Attribute" and use an expression like this:
Searching numbers
You can query numbers using the equal (=), not equal (<>), greater than (>), less than (<), greater than or equal (>=), less than or equal (<=), and BETWEEN operators.
For example
"FORESTCOVER" > 200
JenTaylor1
That would work but I have to get a count for different segments of the line. I thought there was an easy way to even do this in excel.
TimWitt2
I think we need more information. Is the line feature the only feature in your scenario? Or is the forest a polygon and then there is a line feature?
If it is just a forest line segment, after you run my query you can open the attribute table and see in the bottom left, how many segments have been select, this would be your count.
