How to download the CityEngine Web Viewer?
6957
5
10-04-2015 02:23 PM
JamalNUMAN
Legendary Contributor
The help doesn’t clearly say how on can configure\customize CityEngine Web Viewer to display 3D data. how one can start configuring\building 3D web mapping application with the CityEngine Web Viewer?
Thank you
Best
Jamal
Jamal Numan
AbhishekRathi1
Dear Jamal,
Check the link below:
http://www.arcgis.com/home/item.html?id=38fede3935a440e49cf316dcae6aae47
Thanks and Regards
Abhishek Rathi
JamalNUMAN
Thanks Rathi
best
Jamal
Jamal Numan
ThomasFuchs
Dear Jamal,
for more information on using CityEngine to create Web Scenes, please refer the following tutorial:
Tutorial 15: Publish web scenes—CityEngine Tutorials | ArcGIS for Desktop
best
Thomas
deleted-user-OlpHy1NoMNug
Interesting.  For my CityEngine workflow I routinely create scenes that are too large for ArcGIS Online (upwards of 100 mb) and I've been patiently waiting for the ability to publish to ArcServer (I have acces to ArcServer but not Portal which is currently mandatory for web scene publishing).  I know this is on the roadmap for CityEngine this year but does anyone know if I could download the web scene viewer and then host large scenes on my own server.  The bottom of the download link mentioned above makes it seem possible.  Has anyone else tried this?
Use CityEngine Web Viewer application on custom web server
1. download webviewer package from ArcGIS online
*  Open -> download
2. Unzip downloaded package into the web server's document root (or into a subfolder)
3. delete ceviewer.html
4. rename ceviewer_offline.html to viewer.html
5. parallel to the folder webviewer/, create a folder webscenes/
6. place your web scene(s) (.3ws files) in folder webscenes/
7. access Web Scenes in two ways:
  a) reference the webscene with url parameter: http://SERVER.DOMAIN/PATH/TO/WEBVIEWER/viewer.html?3dWebScene=../webscenes/NAME_OF_WEBSCENE.3ws
  b) open the viewer with no parameters, and drag a local 3ws file onto it: http://SERVER.DOMAIN/PATH/TO/WEBVIEWER/viewer.html
Notes:
* For IIS server, .3ws extension needs to be added as MIME type. See http://bit.ly/V8Ftdi
ArnoldKuilman
Yes it is possible! I've been hosting lots of webscenes on IIS, and also on a "LAMP" server. I have however never tried webscenes of 100mb+ size but as long as you can store it, and the browser / viewer can handle it, I think it is possible.
