Calculate age function
10319
8
09-30-2015 08:43 AM
mpboyle
Honored Contributor
Does anyone have a python code block that calculates age based on a date field within a table?  I have tried a few different things but to no success.  Was wondering if someone has successfully done this?
Thanks!
JakeSkinner
Esri Esteemed Contributor
Try replacing the today variable with 'today = datetime.now( )'.  Ex:
from datetime import datetime
def calculate_age(born):
    bornDate =datetime.strptime(born, '%m/%d/%Y')
    return today.year - bornDate.year - ((today.month, today.day) < (bornDate.month, bornDate.day))
JamesCrandall
Use a timedelta.  It should work for seconds, days, weeks, months, years, etc...  Easiest example I found is below.  Just get your minimum and maximum dates in the field/table and determine the difference.
http://stackoverflow.com/questions/1345827/how-do-i-find-the-time-difference-between-two-datetime-ob...
mpboyle
Honored Contributor
James,
If I try finding the difference between today's date and the date in my field, I get an error: unsupported operand type(s) for: 'datetime.date' and 'unicode'.  Is there a way to format the date field to something other than unicode?
Below is the function I have now.  The field I'm passing in for 'bday' is a Date field within a file gdb.
import datetime
def calcAge(bday):
  today = datetime.date.today()
  diff = today - bday
  return diff
JamesCrandall
Welcome to the wonderful world of date manipulation!
I think Jake has your answer below.
JakeSkinner
Hi Matthew,
Here is one option using the field calculator.  The below example worked when I had the date in the format: 8/15/2010.
    today = date.today()
mpboyle
Honored Contributor
Jake Skinner​,
When I try your method, I get an error: 'global name 'date' is not defined'.
JakeSkinner
mpboyle
Honored Contributor
Thanks Jake Skinner​!  This worked
DarrenWiens2
I know this is in the Python section, but if all you need is number of days, VBScript handles it much easier (below is for shapefile, but should work similarly for GDB):
Now (  ) - [YOURDATE]
or years:
CInt((Now (  ) - [YOURDATE])/365)
