Feature service with oracle data
4151
09-25-2015 02:32 PM
DEVAPP
Hi at all,
i have oracle database and i have registered it to enterprise geodatabase but there are some feature in oracle spatial data type.
I have create i view into geodatabase that take data by a join between geodatabase table and geometry data type oracle, and if i try to publish the mxd with this view as feature service i recive error, that the data source is not registered, but the DB is registered on ArcGis server.
i would like to know if i can publish feature service with oracle spatial data
thanks
AsrujitSengupta
Are you trying to Publish the View for editing?
DEVAPP
No, i'm trying to publish a feature service to develop a cluster into client web
AsrujitSengupta
My question was whether you are trying to publish the View as a Feature Service? Which I guess you are doing.
Views are read-only and cannot be edited. It will not let you publish a View as a Feature Service for editing.
DEVAPP
I Must publish feature service for develop a cluster, but the geometry layer is oracle data with join and feature service doesn't mantain the join so i thought to create a view.
i can't use all arcobject or Python, and i have a table geodatabase into write data by store procedure. i must project this data into map and so i create a join with geometry layer because the data doesn't have xy. I must publish this data as feature service for develop cluster but feature service doesn't mantain a join.
So if i create i fc and i use a sql for create a join and after insert into fc the geometry value, i have a fc to publish as feature service.
what do you think?
