Can not connect to SDE when restored from backup
12782
12
09-24-2015 12:24 AM
wentinghan
Hi, All:
    We are tring to restore a sde on db2 from a backup, We use the flowing command to do the restore:
    db2--> restore db SDEDB from /db2/sde5 taken at 20150919163011……
    The restore was successful, we check the table number, index number, they are the same as the old database. Here are the software we are using:
   Database: DB2 9.7.2
   Operating System: AIX 6.1
   SDE: 10.0
   ArcGIS Desktop: 10.0 SP5
   When I try to make a direct connection to DB2  from ArcCatlog, it gave me an error message states:
“This release of the GeoDatagbase is either invalid or out of date. DBMS table not found [SDEDB.SDE.GDB_Release]”;
It is quite strange that “SDE.GDB_Release” is not exist in the source gdb either, but my ArcCatlog works fine with the source DB2.
   Then I try to check out the privileges of the sde user, so I grant the flowing privileges to the SDE, although it may already have these privileges:
CONNECT to database;
CREATETAB in database;
CREATEIN, ALTERIN, and DROPIN for the necessary schema;
EXECUTE on MON_GET_CONNECTION;
CONTROL on database objects, SELECT on SYSIBM.SYSDUMMY1
SELECT on SYSCAT.ROLEAUTH, SYSCAT.DBAUTH, and SYSCAT.TABAUTH
DBADM authority
SYSCTRL or SYSADM authority
Unfortunately, the error remains, I still can NOT make a direct connection to the new DB2.
I already search the google, most of the documents point out it is compatibility between the geodatabase and the ArcGIS Desktop, but we have a 10.0 gdb and 10.0 sp5 desktop.
Any help is appreciate, we are quite desperate, thank you very much.
George_Thompson
Esri Notable Contributor
Hi Wenting,
Did you happen to rename the database during the restore (i.e. was called "database" and is now "databasenew")?
It looks like that might have been the case with the first DB2 command in the post.
ArcGIS Desktop
-George
GeodatabaseEnterprise GIS
--- George T.
George_Thompson
Hi Wenting,
ArcGIS Desktop
-George
--- George T.
wentinghan
Hi, George:
      Yes, I did that. I have changed the database name. Is this a possible reason for that error?
      I will try to restore the db with the same name to see if it will work, will post the result here, thank you very much.
George_Thompson
Hi Wenting,
I think that is the reason for the error. When the database is created there are some tables/triggers/procedures that get hard coded in the geodatabase. If the name changes, then these items break.
I think that if you restore the DB2 database to the new server with the same name, you should be able to connect after that.
-George
--- George T.
wentinghan
Hi, George:
     Thank you very much for your explaination.
     I need several hours to restore the database again, I will post the result here so it can help others.
RebeccaStrauch__GISP
Check  out Vince's instruction for move an SDE to a new server,  pretty straightforward steps.
Re: Migrate from OLD SDE Server to New One
wentinghan
     Thanks, Rebecca.
     The URL you provided talks about ArcSDE On SQL Server. The process is a little different from DB2.
wentinghan
Hi,George:
     We use the same database name when we do the restore, It succeed!
     Thank you very much for your advice, help this post will help others.
JamieLeitch1
I've encountered this same error when trying to connect to an enterprise geodatabase in SQL Server 2017 that had been restored from a backup and renamed using SQL Management Studio.  The problem is that there are several tables and stored procedures that contain the name of the original database that the backup was made from.  To connect to this new renamed restored database, you need to update these tables and stored procedures with the new database name.
Check these tables:
GDB_ITEMS
SDE_column_registry
SDE_geometry_columns
SDE_layers
SDE_process_information
SDE_table_registry
And these stored procedures:
create_version
delete_version
edit_version
You should see the name of the original database within those objects.  Best test what happens in a test db first if you do the find/replace.
George_Thompson
Jamie Leitch‌ you are correct, for SQL Server you cannot rename the DB when restoring. Here is some documentation that may be useful; Methods to move a geodatabase in SQL Server—Help | ArcGIS Desktop    Geodatabase
No matter which of the methods you use to move your SQL Server database, you cannot rename the database. When you restore a database, for example, you are given the opportunity to restore it with a different name. Don't do this with a geodatabase; you won't be able to connect to it.
--- George T.
