Im trying to batch files / loop?
3395
09-24-2015 10:07 AM
Jackie_Oneil
I have a script that I use to convert text files into LAS files- there are 400 files. How would I make a batch script or loop to tell Python to keep grabbing the next file and keep converting until it reaches the end of the folder?
KenTong
You can loop through a folder to get all your text files.
import os
folder= r'path_to_your_folder_of_text_files'
for root, dirs, files in os.walk(folder):
     for filename in files:
          input_file = os.path.join(root, filename)
          # You can then run your conversion script here
          # Use input_file for your input into your script.
jasonramsey1
I would look into using arcpy.da.walk.
DarrenWiens2
Or, since this isn't ESRI data specific, you can use regular old os.walk.
JenniferMcCall4
Hi Jackie,
You could try something like the following:
import os
for filename in os.listdir('dirname'):
     if os.path.isfile(filename):
          # code to convert file here
KenTong
import os
