Bar Chart in Dockable Window C#
670
11-15-2010 05:33 AM
FaizanTayyab
I am trying to create a bar chart using datagraph. However when i assign the feature class table to the datagraph.table property it does nothing (even while debugging, the code stops at this point).
IFeatureClass openedFClass=wksFileFeature.OpenFeatureClass(datasetName);
int fieldIndex = openedFClass.FindField("Customers");
int fieldIndex2 = openedFClass.FindField("Name");
ITable table = (ITable)openedFClass;
MessageBox.Show(table.Fields.FieldCount.ToString());
IDataGraph datagraph;
IDataGraphProperties datagraphProperties;
IField pField1,pField2;
pField1 = table.Fields.get_Field(fieldIndex);
pField2 = table.Fields.get_Field(fieldIndex2);
datagraph = new DataGraphClass();
datagraph.Table = table; Problem on this line..Stops executing.
datagraph.FieldSet1 = pField1.Name;
datagraph.FieldSet1 = pField2.Name;
FaizanTayyab
Solved: Need to create a FeatureLayer from the featureClass and then use:
pDataGraph.Table=(ITable)fLayer;
However does anybody know how to add the genereated DataGraph to a dockable window with a reference
m_dockableWindow
