Problem Adding a proxy file to an asp.net application using that will use portal server
3652
09-21-2015 02:04 PM
HectorAsencio
I have a service located in a portal server. I registered an application and obtained the client id and client secret.I configure the proxy, suing the proxy for .net found here resource-proxy/DotNet at master · Esri/resource-proxy · GitHub​ , however when I run the program and it enters the proxy files, it returns an 403 error unauthorized. I will like to figure out if I make the registration correctly or if there is something wrong with the way I am accessing the proxy the proxy.ashx file that came with the proxy link mention earlier is in its original state. . Here is my proxy.config modified.for my purpose. The code in bold is the one giving me the error when I tried to access it. the code in green are different approaches I've work with to see if they work. I will like to help with this problem I've been stuck for and entire day with these and on the internet I haven't found something concrete that helps me solve this problem.
thank you very much in advance, any help appreciated.
<?xml version="1.0" encoding="utf-8" ?>
<!-- Proxy config is used to set the ArcGIS Server services that the proxy will forward to.
        mustMatch: true to only proxy to sites listed, false to proxy to any site -->
<ProxyConfig allowedReferers="*" mustMatch="true">
    <serverUrls>
        <!-- serverUrl options:
            url = location of the ArcGIS Server, either specific URL or stem
            matchAll = true to forward any request beginning with the url
            token = (optional) token to include for secured service
            dynamicToken = if true, gets token dynamically with username and
              password stored in web.config file's appSettings section.
        <serverUrl url="http://server.arcgisonline.com/"
                  matchAll="true"></serverUrl>
        <serverUrl url="https://services.arcgisonline.com/"
        <serverUrl url="http://services.arcgisonline.com/"
        <serverUrl url="http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer"
        <serverUrl url="http://static.arcgis.com/"
            <serverUrl url="http://gis.hacienda.gobierno.pr/ArcGIS/rest/services/LocalizadorCompuesto/GeocodeServer/findAddressC..."
              oauth2Endpoint = "http://gis.hacienda.gobierno.pr/portal/sharing/oauth2/token"
              cliendId="v******************"
              clientSecret="27***********************"
              matchAll="true"
  <serverUrl url="https://gis.hacienda.gobierno.pr/ArcGIS/rest/services/LocalizadorCompuesto/GeocodeServer/findAddress..."
              oauth2Endpoint = "https://gis.hacienda.gobierno.pr/portal/sharing/oauth2/token"
              matchAll="true"
        <serverUrl url="http://gis.hacienda.gobierno.pr/ArcGIS/rest/info"
              matchAll="true"
       <serverUrl url="https://gis.hacienda.gobierno.pr/ArcGIS/rest/info"
              matchAll="true"
        <serverUrl url ="http://gis.hacienda.gobierno.pr/ArcGIS/rest/services/Movil/ComerciosHacienda_QA/FeatureServer/0"
   <!-- commented code used however commented because it didn't work-->
        <!--<serverUrl url="http://gis.hacienda.gobierno.pr/ArcGIS/"
                 matchAll="true"
  clientId="5s**********"
  clientSecret="0a******************8">
        </serverUrl>-->
        <!--<serverUrl url="https://gis.hacienda.gobierno.pr/portal/sharing/rest/generateToken"
                 matchAll="true"
                 username="************"
                 password="*****************">
        </serverUrl>-->
<!--<serverUrl url="http://gis.hacienda.gobierno.pr/ArcGIS/rest/services/LocalizadorCompuesto/GeocodeServer/"
             oauth2Endpoint = "https://gis.hacienda.gobierno.pr/portal/sharing/oauth2"
             matchAll="true"
      ></serverUrl>-->
                 matchAll="true"
        </serverUrl>-->
                 matchAll="true"
        </serverUrl>-->
      <!--SECURE FEATURE SERVICE EXAMPLE-->
      <!--<serverUrl url ="http://youredomain.com/arcgis/rest/services/Movil/Comercios_QA/FeatureServer/0"
                matchAll="true"
                dynamicToken="true"
                host="youredomain.com"
                userName="YoureUserName"
                password="YourePassword">
      </serverUrl>-->
         <!--<serverUrl url="http://gis.hacienda.gobierno.pr/portal"
      clientId="5*********************"
      clientSecret="0a8***********************"
                  matchAll="true"
            <!--HACIENDA TEST SERVICES   oauth2_endpoint="https://gis.hacienda.gobierno.pr/portal/sharing/rest/oauth2/"-->
      <!--<serverUrl url="http://gis.hacienda.gobierno.pr/"
             matchAll="true"
             username="5s***************"
             password="0a8***************************">
      </serverUrl>-->
    </serverUrls>
</ProxyConfig>
