How to pass username/pass to a Hosted Feature Layer in Python
4725
09-17-2015 02:46 PM
DougBrowning
MVP Esteemed Contributor
I have a simple script to grab the data from a HFS.  It works great if the HFS sharing is Everyone but I can not get it to work with a username/password.
I know that arcpy.SignInToPortal_server was removed (even though it worked great).  I have also tried using he script in a toolbox then run inside of ArcMap but that does not work either.  I do have ArcMap open and signed in.
I use a layer file that points to the HFS.
Any help on the proper way to do this is great.  I am using 10.2.2 but could use 10.3.1 also.
import arcpy
localDB = r"something.gdb"
justPlots = r"JustPlots.lyr"
# Load in from AGO HFS
arcpy.MakeFeatureLayer_management(justPlots, "plots_lyr")
arcpy.Append_management("plots_lyr", localDB + "\\Plots", "NO_TEST")
DougBrowning
I now have it working in a toolbox run from within ArcMap.  Turns out my lyr file went bad somehow.
Would still like any input on stand alone though.
DavinShokes1
If you're primary purpose is to export to fgdb, you could bypass ArcMap altogether with ArcREST Esri/ArcREST · GitHub . This ArcREST/create_replica_fs.py will get you a a local backup of the data (no bidirectional option yet). If you want to keep the data in one location, you can follow ArcREST/query_agol_layer.py to query features since the last backup. The in-memory featureset can then be incorporated with the existing local data via arcpy cursors for fgdb or the pyodbc library for sql databases.
It is also possible to programmatically build 2 way synchronization with arcpy and arcrest. Then you can use windows task scheduler to sync your local version every 15 minutes.
Hope this helps,
Davin
DougBrowning
Do you use the rest to get around the feature return limit?  That seems to be an issue with using the layer file - it will only return the first X records as set in the service.
The create replica script worked great.
The query script gave me this error
C:\Python27\ArcGIS10.2\lib\site-packages\requests\packages\urllib3\util\ssl_.py:90: InsecurePlatformWarning: A true SSLContext object is not available. This prevents urllib3 from configuring SSL appropriately and may cause certain SSL connections to fail. For more information, see https://urllib3.readthedocs.org/en/latest/security.html#insecureplatformwarning.
initialExtent  - attribute not implmented in Feature Layer.
spatialReference  - attribute not implmented in Feature Layer.
size  - attribute not implmented in Feature Layer.
layers  - attribute not implmented in Feature Layer.
tables  - attribute not implmented in Feature Layer.
syncCapabilities  - attribute not implmented in Feature Layer.
units  - attribute not implmented in Feature Layer.
xssPreventionInfo  - attribute not implmented in Feature Layer.
hasVersionedData  - attribute not implmented in Feature Layer.
fullExtent  - attribute not implmented in Feature Layer.
serviceDescription  - attribute not implmented in Feature Layer.
editorTrackingInfo  - attribute not implmented in Feature Layer.
supportsDisconnectedEditing  - attribute not implmented in Feature Layer.
syncEnabled  - attribute not implmented in Feature Layer.
  File "<module1>", line 21, in <module>
  File "C:\Python27\ArcGIS10.2\lib\site-packages\arcrest\agol\layer.py", line 740, in query
    return FeatureSet.fromJSON(json.dumps(results))
  File "C:\Python27\ArcGIS10.2\lib\site-packages\arcrest\common\general.py", line 590, in fromJSON
    for feat in jd['features']:
KeyError: 'features'
Also is there any docs on any of this.  There are many options in the Create Replica but nothing on what they mean.  I was wondering if I could get a locals copy that will show as a replica and then I can sync back and forth with it.  It seems like you can get a copy locally or keep the replica around but not both.
All i can find is the comments in the code
               replicaName - string of replica name
               layers - layer id # as comma seperated string
               keep_replica - if the replica does not have returnAsFeatureClass set to true,
                              the feature service creates a permanent copy of the replica.
                              If this is just a pull, then erase the replica in order to prevent
                              build up of replicas.
               layerQueries - In addition to the layers and geometry parameters, the layerQueries
                              parameter can be used to further define what is replicated. This
                              parameter allows you to set properties on a per layer or per table
                              basis. Only the properties for the layers and tables that you want
                              changed from the default are required.
                                Example:
                                  layerQueries = {"0":{"queryOption": "useFilter", "useGeometry": true,
                                                 "where": "requires_inspection = Yes"}}
               geometryFilter - Geospatial filter applied to the replica to parse down data output.
               returnAttachments - If true, attachments are added to the replica and returned in the
                                   response. Otherwise, attachments are not included.
               returnAttachmentDatabyURL -  If true, a reference to a URL will be provided for each
                                            attachment returned from createReplica. Otherwise,
                                            attachments are embedded in the response.
               returnAsFeatureClass - If a local copy is desired, set this parameter to True, else
                                      the service will return information on how to download the
                                      json file.
               out_path - Path where the FGDB will be saved.  Only used with returnAsFeatureClass is
                          True.
thanks
DavinShokes1
Yes I use it to sync 70k+ features with a business system. The ArcREST code checks max feature count, breaks up large queries into chunks, and then combines them before returning the result.
Its tough to say without seeing the featurelayer.query() line, but try
# Set Geoprocessing environments
    Scratch_gdb = r'C:\Python\scratch.gdb'
    arcpy.env.scratchWorkspace = Scratch_gdb
    arcpy.env.workspace = Scratch_gdb
print fl.query(where="1=1",out_fields='*',returnGeometry=False, returnfeatureclass=True, out_fc='tempfc')
That may help narrow in on the issue.
Also is there any docs on any of this...
                                Example:
                                      json file.
                          True.
This is the only documentation currently.
