Error when playing Map Viewer template Appstudio.arcgis.com
6070
9
09-17-2015 09:21 AM
NathanEnge
Hi. It seems that after the most recent update to appstudio.arcgis.com I am getting error when playing any new app using the Map Viewer template from appstudio.arcgis.com
I am referencing this publicly available web map with an editable hosted feature service: http://www.arcgis.com/home/webmap/viewer.html?webmap=bb0fd3c35496431991674aebf628a29b
and I get the following error when playing in AppStudio player on iPhone and iPad (deleted and redownloaded the app player as well from iTunes)
This error from iPAD 2
This same error in iPhone 5 with iOS8
MarikaVertzonis
Hi Siva
Unfortunately the map viewer issue relies on an updated version of AppPlayer for iOS. This has been sent the store and is pending release.
Regards, Marika
by Anonymous User
Not applicable
Hi Nathan
I was discussing this with Marika at Esri yesterday. In my case, it seems to have been to do with the import statements in my app.
The problem one for me was:
import QtQuick.Controls 1.4
It didn't like v1.4, changing them all to 1.3 made it work again.
I noted that the app still ran from the AppBuilder if they were 1.4, and also when natively compiled, just not through the App Player.
You could try checking your code for this statement or perhaps any other import statement that might be the cause. If the Map Viewer template itself has a problem then I guess either they will need to correct the import statement in the template or update/fix whatever is causing the App Player not to run it...
Cheers,
-Paul
SivaRameshSontineni
Hi Paul,
I am having the same issue but my QtQuick.Controls version shows as 1.1, Please help on this issue
Siva
MarikaVertzonis
Hi Siva
Regards, Marika
SivaRameshSontineni
Thanks for information Marika,
When can this be updated to store. Any idea ?
Siva
RebeccaStrauch__GISP
Siva, for what it's worth, I got a notification for an update to AppStudio Player on my iPad last night.
MarikaVertzonis
Yes, the beta 4 version of player is now available in the iOS store.
MarikaVertzonis
Hold that thought... there seems to be a problem with the version that is now in the ios store - we are working to fix this asap. Sorry for the delay. We will post when its sorted.
ShobanaSuresh
Hi All,
The latest Beta 4 version of Player(Version 1.0.25 built using Qt5.5.0) is now available in the iOS app store.
Below issues are fixed now,
- Map Viewer apps work as expected without errors in Player
- Apps using "import QtQuick.Controls 1.4" work in App Player now
cc: Marika Vertzonis
Shobana
NathanEnge
Thanks. Will give it a go in the morning.
Cheers
Sent from my iPhone
