Create contours from "text" data type for a point feature class?
2988
09-15-2015 10:13 AM
MichaelSims1
I created a point feature class and want to contour the points based off of subsurface depths I have input into the "text data type" field. Is there anyway to generate contours without having z-values?
NICOLAPEDDIS
In the point feature must be present the z values to make a contour or use 3D analyst/spatial analyst
JayantaPoddar
Hi Michael,
The sub-surface depths that you entered, can be used as the z-value. USe the Field's datatype as DOUBLE.
First create a DEM using the z-field of point layer.
Topo to Raster—Help | ArcGIS for Desktop
Then, create isolines (contours) from the above DEM.
Contour—Help | ArcGIS for Desktop
Think Location
