Python if then codeblock in field calculator
6397
5
09-14-2015 07:45 AM
KeithAddison1
I need to write an if then code block for field calculator to see if the value in field A equals 0, and if it is to make the value in field B equal -1.  Else do nothing.  How can I do this?  FIeld A is type float & field B is type interger.
RyanClose
Assuming you are using ArcMap since you mentioned field calculator:
Right click the field you wish to change to -1 and calculate that field.
Switch the radio button to Python
In the code block enter:
def changefield(whatif,okthen):
  if (whatif == 0):
    okthen = -1
  return okthen
Then in the text box below FIELDB  =
Enter: changefield(!FIELDA!, !FIELDB!)
DanPatterson_Retired
They can be emulated using this syntax
simple comparison and reclass
  " True condition " if !some_field! == "some_value" else " False condition "
ie .  "Agricultural 10 Acres" if !Zone! == "A-10" else "False"
1  if !A! == 0 else -999
assuming you are calculating in the B field, using python and you can't do nothing...so I put in -999 and you can replace it with integer nothingness
RyanClose
  if (whatif == 0):
    okthen = -1
  return okthen
JoshuaBixby
MVP Esteemed Contributor
Python has conditional expressions, a.k.a., ternary operators, that can be used in situations like this one.  Using a ternary operator eliminates the need for using a code block and defining a function.
-1 if !FieldA! == 0 else !FieldB!
hmmm my previous thoughts exactly
RyanClose
Excellent. Nice to know!
