“add to display” option for models created in ArcGIS Pro,
6210
7
09-13-2015 01:08 AM
JamalNUMAN
Legendary Contributor
I couldn’t figure out how to set select the “add to display” option for models created in ArcGIS Pro,
Thank you
Best
Jamal
Jamal Numan
DanPatterson_Retired
they have to be model parameters to be added to the display
https://pro.arcgis.com/en/pro-app/help/analysis/geoprocessing/modelbuilder/modelbuilder-tutorial.htm
filtering through the help will show you the differences between 10.x and pro
https://pro.arcgis.com/en/pro-app/help/main/welcome-to-the-arcgis-pro-app-help.htm
JamalNUMAN
it works fine. In ArcGIS Desktop, the (P) indicates for a totally different feature!
Jamal Numan
P  ==>  It is either an input parameter (which you get to specify when the model is run) or an output parameter (something that is created and you get to specify its name for instance).  If there is no P... then it will be hardcoded in the model and not added as a result to the display
JamalNUMAN
Thanks Dan.
Jamal Numan
JamalNUMAN
Is there any option that can be set in order to get “add to display” selected by default so that the out is added automatically to the table of content?
Jamal Numan
JamalNUMAN
In 2.5, there is no need to let the output as “parameter” in order to get the “add to display” option available
Jamal Numan
Aaron_King
Hey Dan,
When one is enjoying the benefits of having one's model output added to the display through the empowering of this nifty verdant check mark, is it possible to enjoin ARCPRO to reproduce said data into the Table of Contents under its actual name instead of the name of the Blue Bubble in which it resides in the Model space?
