Sequential numbering
5918
6
09-10-2015 09:13 AM
CCWeedcontrol
I have two layers with building footprints I need to update one of them. After merging layers I have some features with an sequential number in the field Bld_ID field but some don't. So i need to update the Bld_ID with sequential number and they start with "Bld": example bld000001, bld00002, bld00003, etc. So some how i need to find the last highest sequential number in the field Bld_ID then add 1 to that and use that to update the buildings i have selected.
I have a code i used for something similar but i am running into the an error with this any help would be appreciated:
Runtime error
  File "<string>", line 30, in <module>
IndexError: list index out of range
import arcpy, sys, re, os
from arcpy import env
import string
arcpy.env.qualifiedFieldNames = False
Bld = "BuildingFootprints" #target point feature class
BldCount = int(arcpy.GetCount_management(Bld).getOutput(0))
dsc = arcpy.Describe(Bld)
selection_set = dsc.FIDSet
if len(selection_set) == 0:
    print "There are no features selected"
elif BldCount >= 1:
    #Gets the highest AddressID and calculates new point to assign new highest AddressID
    Bld_list = []
    with arcpy.da.SearchCursor(Bld, ["Bld_ID"]) as cursor:
        for row in cursor:
            try:
                if "Bld" in row[0]:
                    Bld_list.append(int(row[0].strip("Bld")))
            except TypeError:
                pass
    del cursor
    Bld_list.sort()
    Bld_ID = Bld_list[-1] + 1
    Bld_ID = 'Bld' + str(Bld_ID)
    with arcpy.da.UpdateCursor(Bld, "Bld_ID") as rows:
        for row in rows:
            row[0] = Bld_ID
            rows.updateRow(row)
        del row
        del rows
JakeSkinner
Esri Esteemed Contributor
I believe the problem is that you are running this in ArcMap, so your variable Bld is running off the selection of the feature class rather than the entire feature class.  This is why the list was returning empty.   You can set up two variables:
arcpy.env.workspace = r"C:\temp\python\test.gdb"
BldSelection = "BuildingFootprints"
Bld = arcpy.env.workspace + os.sep + "BuildingFootprints" #target point feature class
You will also need to update your updateCursor to add to the Bld_ID.  Try the following:
import arcpy, os
dsc = arcpy.Describe(BldSelection)
elif BldCount >= 1:
    Bld_list = []
        for row in cursor:
            try:
                if "Bld" in row[0]:
            except TypeError:
                pass
    del cursor
    print Bld_list
    Bld_list.sort()
    with arcpy.da.UpdateCursor(BldSelection, "Bld_ID") as rows:
        for row in rows:
            row[0] = 'Bld' + str(Bld_ID)
            Bld_ID += 1
            rows.updateRow(row)
        del row
        del rows
Note:  You will need to update line 3 to the path of your feature class.
DarrenWiens2
Make sure len(Bld_list) > 0. If the list is empty, there is no item at Bld_list[-1].
CCWeedcontrol
The list shouldn't be empty, there are features that have a bld00001, bld00002, etc numbering in the Bld_ID field.
thanks for the reply.
DarrenWiens2
Just add a print Bld_list to figure out if the list is empty.
JakeSkinner
import arcpy, os
elif BldCount >= 1:
    Bld_list = []
        for row in cursor:
            try:
                if "Bld" in row[0]:
            except TypeError:
                pass
    del cursor
    print Bld_list
    Bld_list.sort()
        for row in rows:
            Bld_ID += 1
            rows.updateRow(row)
        del row
        del rows
CCWeedcontrol
Jake the code you posted worked but it truncated the "zero's" like so Bld4, Bld5, Bld4. etc.
How can get them to be like so Bld00004, Bld00005, Bld00003, Bld001069?
LanceCole
Use ​'Bld%06d' %Bld_ID rather than 'Bld' + str(Bld_ID)
