Python script and Hyperlinks
8520
11
09-04-2015 12:58 PM
RobertMateja
Hyperlinks have always been an issue for me.  Dynamic hyperlinks are only available in the .mxd which won't work for me.  I thought attachments were going to be the way to go until I started researching and found out that the attachement is stored in the geodatase.  Unfortunately, this won't work for our workflow.  Record maps are constantly being updated which means that every update would result in several steps to keep the attachment up to date.  Too bad attachments can't just store the path to the file location, but I digress.
So i have been using hyperlinks.  This works great when I only have one file linked to a feature class.  Unfortunately, we have several features that have multiple files.  I have been storing these in my hyperlink field separated by a "|".  So I may have the following entry
\V09\VBP001.tiff | \V09\VBP006.tiff
In these cases the hyperlink tool will not work.  I am looking for a way to have my python script to split the above entry and open both files.  This is what I have so far
import webbrowser
def OpenLink ( [FIELD] 😞
  path = 'PATH' + [FIELD]
  webbrowser.open(path)
  return
This works great for hyperlinks that only have one file.  I cannot figure out what I need to add to open multiple files separated by the "|"
thanks for the help
IanMurray
Honored Contributor
you could parse out each path individually using [FIELD].split(" | ") and make a for loop that opens each parsed path.  Even if it has only 1 record, it will still return a list of string(s).
test = "Test1 | Test2"
test2 = "Test1"
print test.split(" | ")
['Test1', 'Test2']
print test2.split(" | ")
['Test1']
just would need to add "PATH" in front of each.
import webbrowser
def OpenLink ( [FIELD] ):
  pathlist = [FIELD].split(" | ")
  for path in pathlist:
    fullpath = 'PATH' + path
    webbrowser.open(fullpath)
  return
EDIT: Updated code to final.
IanMurray
Honored Contributor
test2 = "Test1"
['Test1', 'Test2']
['Test1']
import webbrowser
  return
BlakeTerhune
You could use the split() method to get your hyperlinks in a list (EDIT: Ian beat me to it).
If you have a one to many relationship between features and files, and you're using code to make it work, maybe you could just store your hyperlink paths in a related table with a key to the feature instead of just a single field in the feature class.
And, FYI, the | character is called a pipe.
RobertMateja
Ian and Blake,
Thanks for replying.  Using the split method is kind of working.  It will open the first file (before the pipe - Blake, thanks for pointing that out.  I had no idea.). I would like it to open each file at the same time.  I am not sure if that is even possible.  Any thoughts?
thanks
rob
IanMurray
Honored Contributor
So is it not opening subsequent hyperlink if there is more than one?
RobertMateja
that is correct.
IanMurray
Honored Contributor
move the return in my script outside the for-loop, I think it is causing it to end the loop prematurely.
RobertMateja
I think I follow what you are saying but I keep getting an indentation error.  This is what I have
import webbrowser
def OpenLink ( [HYPERLINK] 😞
    pathlist = [HYPERLINK] .split(" | ")
       fullpath = "U:\LWATER\SCANNED" + path
return
IanMurray
Honored Contributor
the return needs to be within the function, but outside the for-loop.
import webbrowser
    return
Also, you had 3 spaces for the for-loop indent, but 4 spaces for the function.  I went ahead and made it 4 and 4.
RobertMateja
Ian,
That worked.  Thanks so much. This is going to be a huge time saver!
rob
