multiple spatial analyst failures, 10.2
3133
09-03-2015 04:42 AM
PhilCrossley
I am trying, with a room full of students, to do any/all of the following: mosaic 4 adjacent DEMS (2x2), perform focal statistics (neighborhood mean) to fill missing data, run the basic suite of surface analysis functions.  I have done this many times, with all versions and in the past any problems have been due to file/path names.
This week, the same methods (using Mosaic to New Raster tool) that have always worked (as recently as May) fail repeatedly, generating the "Failed to open raster dataset" generic error/red X report.  We are running 10.2 on local machines, but saving to a server (all have read/write privleges to a specific directory)
I/we tried:
checking file/path names
(re)setting the workspace (though I didn't think to check the scratch workspace)
shutting down ArcMap and opening again; rebooting the whole computer....
reloading all 4 DEMs
running any one of the surface analysis functions that have always worked with problem--but getting the same failure message
getting a new copy of all 4 DEMS (yes, all with the same spatial metadata)
loading just a single DEM and trying any surface anal. function..........but still getting the error
Except that some machines/students will do everything just fine, and others can't get anything to work (and I've watched the process and even done the clicking);
One student did a series of surface analysis (and Euclidean distance) steps without problem 2 nights ago, and last night couldn't even get slope to run on a single DEM.....
Does this sound like a 10.2 problem (vs. 10.1 and all previous)?
What else can explain this near universal failure to run Spatial Analyst to do things that have always worked easily before?
Is there still a way to use Raster Calculator to run these processes (like we used to do, but I thought this functionality had been eliminated)?
any suggestions welcomed!
Phil Crossley
DanPatterson_Retired
A sure sign that you had a project that didn't use relative paths and/or the data was moved to a new location relative to the project ... or.. you have server issues...solution...try putting the data on a local machine with no weirdness in the path names (spaces, filename length, blah blah) as I am sure you are now aware.  If it works local, move up to global
PhilCrossley
Thanks.  Am about to do the local vs server test which was my plan anyway.  I don’t think any of the students had even saved a project file yet, let alone moved one (they were all working with a blank map to start with), but I will also test with relative paths.
thanks
Update:  everything works perfectly and easily in my office; nothing works in lab......(except the Mosaic to New raster tool suddenly works but no other surface analysis or neighborhood statistics will (after 9999999 error message, a new raster created and visible in ArcCatalog (in spite of the error message)...........and missing data values filled in, but no spatial reference attached............)...
Still sound like just 'server issues'?  Any suggestions about specific problems to suggest to IT?
