ArcPy- Enable time on this layer
4844
09-03-2015 09:22 AM
IanIrmischer
I have over 1000 feature classes that I am loading into a map document.  I have figured out how to automate this process in using Arcpy.  Each feature class has a field with datetime.  I can enable time on the layers one by one by right clicking on the layer once it is in arcmap and clicking the box "enable time on this layer". I would like to automate the process using arcpy.  Can anyone help?
Ian
Tags (1)
FreddieGibson
Honored Contributor
Is this a duplicate of the following thread?
https://community.esri.com/thread/164863
DanPatterson_Retired
Freddie, yes it is.  Apparently the original wasn't posted in the correct place.
It also appears to be a duplicate of this thread
https://community.esri.com/thread/164869
which was discussed and apparently answered.
It would be useful to indicate which software and/or development environment you are using otherwise your threads will languish in the great void of unanswered and lost questions.
