Python Ascii to Raster
5753
7
09-03-2015 04:03 AM
robsimpson
Hi have around 100Asciis i need converting to rasters. I have this little script
# Import system modules
import arcgisscripting, os, sys
# Create the Geoprocessor object
gp = arcgisscripting.create(9.3)
# Set local variables
InAsciiFile = None
inDir = r"E:\Hull Deliverables - Final\Defences Operating\DepthGrids\1d"
OutRaster = r"E:\Hull Deliverables - Final\Analysis for Duty\allascii\rast"
for InAsciiFile in os.listdir(inDir):
    if InAsciiFile.rsplit(".")[-1] == "asc":
        print InAsciiFile
# Process: ASCIIToRaster_conversion
gp.ASCIIToRaster_conversion(os.path.join(inDir,InAsciiFile)), os.path.join((OutRaster,InAsciiFile.rsplit(".")[0][:9]), "FLOAT")
but for some reason i get the following error
  File "H:\Documents\python\asciitorast3.py", line 17, in <module>
ExecuteError: Failed to execute. Parameters are not valid.
ERROR 000885: Input ASCII raster file: E:\Hull Deliverables - Final\Defences Operating\DepthGrids\1d\info's does not have a file extension.
ERROR 000859: The required parameter Output raster is empty, or is not the type of Raster Dataset.
Failed to execute (ASCIIToRaster).
any help would be appreciated
thanks
Tags (4)
ChrisSmith7
Honored Contributor
Rob,
See Ian's answer below!
I'm going to leave the doc link in my answer though!
http://help.arcgis.com/EN/arcgisdesktop/10.0/help/index.html#//00120000002s000000
IanMurray
Honored Contributor
I think the problem is you are setting InAsciiFile = None, and never changing its value except in the for-loop which is a local variable, not global.  Since your ASCIItoRaster_conversion is outside the forloop, it uses the None as an input with os.path.join not the file name.  Move the conversion in the forloop so it can use the local variable InAsciiFile, not the global value.
ChrisSmith7
Honored Contributor
Ah, wow - I must have had a long night, lol.
robsimpson
Im new to python so sorry for the probably basic question, i think i did as you mentioned above but now get the following error
  File "H:\Documents\python\asciitorast3.py", line 14, in <module>
AttributeError: 'NoneType' object has no attribute 'rsplit'
Thakns for the help so far
DanPatterson_Retired
It still doesn't have the filename.  perhaps if you could post some revised code it could be check.
I will demonstrate by example using the following
>>> InAsciiFile = None
  File "<interactive input>", line 1, in <module>
Spot the error?
you have a dash in the folder path...try locating the data elsewhere
SteveLynch
in your Py script, print the value of
once and in ArcMap paste the result into ASCIIToRaster and see if the tool runs.
-Steve
