Create a drop down in python code
2856
09-01-2015 05:54 AM
WesMiller
Is it possible to create a drop down in python code? You could in VBA, I don't remember what's terminology.example below.
This code will size and position an element on the map layout. What i would like is for the element type to be a drop down list for the various types.
def sizeposElm(elmName,elmType,elmWidth,elmHeight,elmX,elmY):
    """Element Name, Element Type, Element Width, Element Height, X Position, Y Position"""
    elm = arcpy.mapping.ListLayoutElements(mxd, elmType, elmName)[0]
    elm.elementWidth = elmWidth
    elm.elementHeight = elmHeight
    elm.elementPositionX = elmX
    elm.elementPositionY = elmY
    del elm
sizeposElm("legend","DATAFRAME_ELEMENT"
                    "GRAPHIC_ELEMENT"
                    "LEGEND_ELEMENT"
                    "MAPSURROUND_ELEMENT"
                    "PICTURE_ELEMENT"
                    "TEXT_ELEMENT"
JakeSkinner
Esri Esteemed Contributor
Hi Wes,
Take a look at Creating a Python Add-In Combo Box.
WesMiller
Thanks for your response Jake. I was hoping for something more like code intellesense where i could create the above code and when i got to a known set of values i could just select them while typing in my code verses having to type or copy and paste them in every time.
