Integrating C++ code With ArcGIS Button
3198
08-28-2015 11:45 AM
MasroorHussain
I have a c++ code that works with GDAL and do some raster processing. I want to create a button in ArcGIS Desktopm pass the raster layer loaded in ArcGIS and then access raster (pixel) values in the c++ code.
Is there an example for such a project ?.
Sincerely,
Masroor
AlexanderNohe1
Honored Contributor
For creating the button, you should look at the following documentation:
developer-support/arcobjects-c++/create-command-atl at master · Esri/developer-support · GitHub
As for the other parts, I am unable to find many examples just yet.
AlexanderNohe1
Honored Contributor
MasroorHussain
Hi Alexander,
I am successful in following the example and creating a button that works in ArcGIS 10.3.
Can you please guide me how to link it to ArcGIS 10.3 for debugging - i.e. launch from Visual Studio 2013 and ArcGIS launches and I could debug.
Sincerely,
Masroor
AlexanderNohe1
Honored Contributor
After you launch ArcMap, add break points to your code and then attach to process in Visual Studio to ArcMap.
When you press the button, you should be able to step through your code.
