Operations Dashboard not showing dynamic data
2932
08-26-2015 10:40 AM
DavidDow
I'm working my way through the Redlands Emergency Response tutorial and am on the section regarding setting up an operational dashboard. I previously setup the web map in my Arcgis Online portal with 4 of the 5 layers having dynamic refresh capabilities per the instructions and everything is saved. The web map works as expected. When choosing this web map as a "map widget" in the operational dashboard the settings show all of the layers as static even though only one of the layers is static. Is there any way to correct this? Is there some setting in the web map I'm missing? I'm not sure why they show up as static when they are clearly dynamic in the web map.
DavidDow
Also, I can load the "Redlands Emergency Response (Demonstration) map" as a widget and its layers do show as dynamic as expected. In comparing the details between the two web maps (mine on my own portal and ESRI's) , they appear to be functionally identical.....
