Getting Wrong Result using Spatial Filter in SQL Query
4304
08-22-2015 11:41 PM
RavindraSingh
I have a python script where I am executing SELECT SQL statement, using Spatial filter.
The geometry I am using in Spatial filter is being passed as parameter to the python Script.
Now the Issue IS::
Query is running fine. But:
  1. for some of the Geometries,SQL is not giving correct output, as compared to the same SpatialFilter applied in ArcMap. E.g. SQL Return 3 where as ArcMap Returns 4. and I can clearly visualize in ArcMap, that feature is overlaping.
  2. So to overcome above issue, I commented out the Code of SimplifyPolygon in my Python, and I used original Geom. Now the Result is coming Correct, same as What I am getting in ArcMap.
  3. Now this leads to another issue.:: For some of the geometries. It gives me below error while executing SQL Query:
    ArcSDESQLExecute: StreamPrepareSQL ArcSDE Extended error 1704 ORA-01704: string literal too long
scratch = arcpy.env.scratchGDB
polyLayer = os.path.join(scratch,"inputPoly")
simplePolyLayer = os.path.join(scratch,"simplePoly")
arcpy.MakeFeatureLayer_management(parameters[0].valueAsText, polyLayer)
arcpy.cartography.SimplifyPolygon(polyLayer, simplePolyLayer,"POINT_REMOVE", 5)
count = int(arcpy.GetCount_management(simplePolyLayer).getOutput(0))
arcpy.AddMessage("count: " + str(count))
if count > 1:
     #need to merge into a multipolygon then get the WKT
     merged = os.path.join(scratch,"mergedPoly")
     arcpy.Dissolve_management(simplePolyLayer, merged)
     for row in arcpy.da.SearchCursor(merged, ["SHAPE@WKT"]):
          WKT = row[0]
else:
     for row in arcpy.da.SearchCursor(simplePolyLayer, ["SHAPE@WKT"]):
          WKT = row[0]
SQL Query code.
"SELECT count(*) FROM " +<My_FeatureClass> +" a WHERE served_id = 0 and (sdo_anyinteract(a.shape,sdo_geometry('" + WKT + "',4326)) = 'TRUE')"
Let me know any solutions.
Message was edited by: Ravindra Singh
RavindraSingh
I found the solution regarding this.
Following are the steps you need to do.
  1. Download most Suitable version as per your system  of cx_Oracle
  2. Install the above . It will be installed at default location-   "C:\Python27\ArcGIS10.2\Lib\site-packages" .  Let it install at here only.
  3. NOTE::    If any ESRI product is already opened. Then close it, then Open ArcMap, to let the changes take effect.
  4. now modify your script as below:
# Import the package as below
import arcpy, os, sys, arcpy.cartography
#Importing package for making SQL Connection with Oracle
import cx_Oracle
# -- [Strart] Code to get the Geometry as WKT .
count = int(arcpy.GetCount_management(polyLayer).getOutput(0))
if count > 1:
     arcpy.Dissolve_management(polyLayer, merged)
          WKT = row[0]
      else:
           for row in arcpy.da.SearchCursor(polyLayer, ["SHAPE@WKT"]):
                WKT = row[0]
# -- [END] Code to get the Geometry as WKT .
# Create Oracle Connection.
connection = cx_Oracle.connect('<Database_UserID>/<pwd>@<Service_Name>')
cursor = connection.cursor()
mySpatialSQLQuery = "SELECT count(*) FROM PLOTS a WHERE served_id = 0 and (sdo_anyinteract(a.shape,sdo_geometry(:WKTGeom,4326)) = 'TRUE')"
#in the above query ':WKYGeom' is the place holder whose value we will pass in next.
WKTGeom = WKT
cursor.setinputsizes(WKTGeom=cx_Oracle.CLOB)              # prepare memory for operation parameters
cursor.execute(plotCountSQL, {'WKTGeom':WKTGeom})   # Executing using Binding Variable using CLOB
res = cursor.fetchall()
plotCount = res[0][0]               # It Denotes First Row's First Column
#arcpy.AddMessage("plotCount using cx_Oracle== "+ str(plotCount))
cursor.close()
Like this you can pass the huge geometry as WKT format.
Hope this will help someone.
Cheers !
RavindraSingh
import cx_Oracle
if count > 1:
          WKT = row[0]
      else:
                WKT = row[0]
WKTGeom = WKT
cursor.close()
Cheers !
