Change default open location for widget
3473
08-24-2015 08:56 AM
mpboyle
I'm wondering if it's possible to change the default open location for widgets that use the Launchpad theme using the Web AppBuilder developer edition 1.2?
Instead of widgets opening on the left-hand side of the screen where it covers the zoom-in, zoom-out, and home widgets, I was wondering if it's possible to have them open on the right-hand side where generally there is open screen real-estate and won't cover up any other widgets...?
I'm assuming some .js or .css file needs to be altered in order to do this, just wondering if it's doable...?
Thanks in advance!
ChrisSmith7
Honored Contributor
I haven't had a chance yet to dive into the JavaScript-based web app builder, but according to the documentation, there are widget configuration options you can set, including position:
Widget configuration—Web AppBuilder for ArcGIS (Developer Edition) | ArcGIS for Developers
ChrisSmith7
Honored Contributor
Also, if you are curious, here's the CSS class reference:
CSS framework—Web AppBuilder for ArcGIS (Developer Edition) | ArcGIS for Developers
