Adding an ArcGIS Online Layer
4261
08-21-2015 02:17 PM
DanEstersohn1
When I try to "Search for Layers" from my AGO organization, the choice of ArcGIS Online is not available in the "In" drop down box.  My only choice are:
     My Organization
     A GIS Server
     Living Atlas Layers
None of these choices get me to the layers I want (i.e. the Red Rock Canyon Trails for ArcGISBook, Chapter 4 Lesson).
DanE
Tags (1)
XanderBakker
Esri Esteemed Contributor
You mean that you are logged on to your organization and when you want to add a layer from ArcGIS Online the option is not there. I think I can reproduce this... If I log on to the organization and create a new map to which I want to add the layer I see the options; My Organization, A GIS Server and the Living Atlas (sorry for the Spanish interface):
If I log out and try again I see that the ArcGIS Online option appears:
... and it finds the layer:
What you could do is search for the layer on arcgis.com where you find the item:
http://www.arcgis.com/home/item.html?id=c996394d2ca74c038f00e6bc15a9663c
There you can add the layer to the current map (and this time sorry for the Dutch interface... yeah, don't ask):
What you should check with the administrator of you ArcGIS Online for Organizations is the Security setting of the site (once again sorry for the Spanish interface):
Maybe in Share and Search the second option is switched off, which allows users to search content outside the organization. Could you check this setting?
by Anonymous User
Not applicable
Hi Dan,
Have you tried this in any other browsers? Have you tried clearing the browser cache?
XanderBakker
DanEstersohn1
Thank you Xander.  Changing the security settings worked.
XanderBakker
Glad it worked!
