How to use values from arcpy.GetParameters in expression?
7062
08-15-2015 09:08 AM
GabrielaMandziuk
Hi, I have a big big problem
I am writing a script in PythonWin and want to use it as a Script in ArcGIS toolbox (I have created a script in ArcMap and it is linked with pythonWin script).
I really want to make some parameters to enable users of my tool to set their own settings. This is my code:
import arcpy
from arcpy import env
env = "C:/Users/Desktop/an1"
inputfc = arcpy.GetParameterAsText(0)
outputfc = arcpy.GetParameterAsText(1)
dateFrom = arcpy.GetParameterAsText(2)
dateTo = arcpy.GetParameterAsText(3)
xyTolerance = arcpy.GetParameterAsText(4)
select = inputfc + "_sel"
where_clause = ' "DATE" > date \'dateFrom\' AND "DATE" < date \'dateTo\' '
arcpy.Select_analysis(inputfc, select, where_clause)
As you see, I want to get the date from the value of parameter. Unfortunately, I cannot find a way to use it in my where_clause expression!
("DATE" is a field name). How can I access to these values? The problem is, as I suppose, in the expression itself. When I paste a normal date there (like: where_clause = ' "DATE" > date '2015-01-01' AND "DATE" < date '2015-02-01' '​) everything works.
Thanks!:)
GabrielaMandziuk
Hi. I have finally solved my problem!!!
As I thought, the problem was in the expression. Now the code is:
import arcpy
dateFrom = arcpy.GetParameter(2)
dateTo = arcpy.GetParameter(3)
where_clause = '"DATE" > date \'%s\' AND "DATE" < date \'%s\' ' % (dateFrom, dateTo)
integrated = select + "_int"
arcpy.CopyFeatures_management(inputfc, integrated)
arcpy.Integrate_management(integrated, str(xyTolerance) + " Meters")
ce = arcpy.CollectEvents_stats(integrated, outputfc)
Hope it'' help someone in the future
DanPatterson_Retired
You need a date field...do you have a Date field? and do the dates conform to what you say works?  You can create a derived parameter if you had a field parameter, set to default, then the values derived from it.
http://desktop.arcgis.com/en/desktop/latest/analyze/creating-tools/setting-script-tool-parameters.ht...
http://desktop.arcgis.com/en/desktop/latest/tools/analysis-toolbox/select.htm
SQL syntax is covered here
http://desktop.arcgis.com/en/desktop/latest/map/working-with-layers/sql-reference-for-query-expressi...
GabrielaMandziuk
My parameter has a data type "Date" and I do have a DATE field in my feature class attribute table. I will study your materials, thanks for the answear
GabrielaMandziuk
import arcpy
