Data loss when synchronizing local edits to server
4064
08-06-2015 11:42 AM
JoshVan_Vlack1
I'm pulling my hair out with one of my data sets losing any edits I make in Desktop, but keeping edits mad in AGOL....
I have a hosted feature layer that contains points for active and controlled wildland fires. I need to be able to drop new features in rapidly, based on their Lat/Long. Desktop's "go to X Y" function lets me do this without much heartburn... but here is the rub...
Here is my workflow, which works with every other dataset besides this one...
Add layer from AGOL> Make local copy for editing> make edits (add points & attributes)> save edits> stop editing> synchronize local edits with server.
Right after the synchronization stops, all new features I added disappear. But if I add features in AGOL, they stick fine.
Like I mentioned, this is the only feature layer that has this problem. I tried recreating it from scratch, and the new version has the same problems.
Any ideas?
RichardBurdett1
I have the same problem!
No one answering It seems!
KellyGerrow
Esri Alum
Thanks for contacting Tech Support. Please update the post with the results of the support case when resolved.
-Kelly
RebeccaStrauch__GISP
You may want to create a ticket with tech support so they can look into this.
