ApplyEdits geometry from javascript API
4198
08-04-2015 08:42 AM
Lars_HalvorAnundskaas
I drew a graphic on a graphic layer (sample)
When running this through applyEdits on a featureLayer i get a success in return, but the geometry in the database becomes null or invalid.
If I draw a simple square or a circle, I don't see the same problem.
I also tried to take the same geometry into arcmap using json to features, the geometry appears correctly.
I have attached a sample JSON which does not work through applyEdits (even though it returns success and attributes are saved)
However, the shape looks perfectly well when importing using json to features.
Any hints on what could I could do wrong?
10.3.1 did not give me any error message, but 10.2.1 did:
The solution; to run simplify on the geometry when necessary
if (esri.geometry.polygonSelfIntersecting(geom)) {
      geom = geometryEngine.simplify(geom);
Simplify a polygon | ArcGIS API for JavaScript
KenBuja
MVP Esteemed Contributor
Has polygonSelfIntersecting been replaced by the polygon method isSelfIntersecting?
