Geoprocessing Script to Clip based on Two Attributes
5415
14
08-04-2015 06:38 AM
JasonFultz
Hi All,
I am looking for a method to do a clip based on two attributes.  In the attached shapefile, I have a "Year" field with years ranging from 0 to 27 and a "COLOR" field populated with either Red or Green.  I am looking for the best way to cycle through each year and clip the Red polygons from the Green polygons (discarding the area that intersects).  Is a python script or iterative model the best approach for this?  I am still a novice python user but very interested in learning more about it.  Any help with this would be greatly appreciated.
Jason
WesMiller
The script below should get you started. Open a new arcmap and add your Topsoil layer open your arcmap python window right click behind the ">>>" and select load and load this script hit enter and watch it run.
import arcpy,os
fc ="Topsoil"
y = 28
out_path = "in_memory"
#Create results featureclass
results = "results"
arcpy.CreateFeatureclass_management(out_path,results,"POLYGON",fc)
for i in range(y):
    greenquery = '"COLOR" =' + "'Green'"
    redquery = '"COLOR" =' + "'Red'"
    value = str(i)
    if len(value) == 1:
        value = "0" + value
    value = "Y"+value
    yearquery = '"Year" ='+ "'%s'"%(value)
    Rquery = yearquery + "AND" + redquery
    Gquery = yearquery + "AND" + greenquery
    redLayer = "Red" + value
    greenLayer = "Green" + value
    #Create red layer
    arcpy.MakeFeatureLayer_management(fc,redLayer,Rquery)
    #Create green layer
    arcpy.MakeFeatureLayer_management(fc,greenLayer,Gquery)
    #print int(arcpy.GetCount_management(redLayer).getOutput(0))
    if int(arcpy.GetCount_management(redLayer).getOutput(0)) > 0:
        #do the clip
        #print value
        clip = "clip"+value
        arcpy.Clip_analysis(greenLayer,redLayer,os.path.join(out_path,clip))
JasonFultz
Wes, Thank you very much for the reply and for providing the script.  I'm afraid I'm going to show how much of a true Python novice I am by asking if there is a way to save this script that you supplied? I am unable to import it into Python window without it being saved as a .py file.  Is there a way to save if from GeoNet as a .py file?
Thanks again,
Jason
WesMiller
Highlight the code press "ctrl" key and the "c" together or with the code highlighted right click and select copy. Then open the python IDLE and under "File" select "New Window" and click in the new window and press "ctrl" and "v" key together or right click and select paste then save the code to a location and make sure to give a meaningful name ( a name that will tell you what the code is) and end it with ".py" you'll then be able to add to your arcmap python window
JasonFultz
When I tried this method, I received the following error in the screenshot.  I copied/pasted it into the python IDLE and saved it as a .py.  I then loaded it into the python window in ArcGIS and received the following syntax error.  I feel its because the method of copy/paste.  I would guess that the syntax error is because of the numbers getting copied over as well.  Any thoughts?
WesMiller
The code is attached
JasonFultz
Thanks, Wes.  I get the following error when I run the script. Any ideas?
WesMiller
Sorry, try this one.
JasonFultz
Thanks, Wes.  This script ran fine, but it made me realize I perhaps want to do an Erase rather than a Clip.  I believe I described this task incorrectly when I first posted, my apologies.  I am looking to eliminate the overlap between the red and green polygons for each year. Although I would like to still keep both the red and green polygons for each year, just eliminate any overlap between them. I can try to modify the script you provided to run an Erase instead of Clip.
I do have one more question.  I noticed that when I ran the latest script you provided, it produced a new shapefile for each color for each year (screenshot below).  Ideally, I would like to end up with one shapefile that contains all polys, which still maintains year and color, only with the red/green overlap erased by year.
Thanks again for the help you have given me with this task.
Jason
WesMiller
Jason the script creates 3 files for every year that has features with red. If I remember correctly Y00 and Y01 didn't have any red features to use. I think if you check just those years that begin with clip they may be what you are describing. If that is the case you just need to generate a list and feed it into the merge tool ArcGIS Help (10.2, 10.2.1, and 10.2.2)
