Python Script Tool Parameters
4064
08-03-2015 10:01 AM
JacobSnyder
Is there a limit to the number of parameters that you can set when creating a Python script tool in ArcGIS? I have created a script that contains 9 parameters, and I cannot seem to add the last parameter to the script tool when attempting to do so by opening the script tool properties. Thanks so much.
-Jacob Snyder
Luke_Pinner
MVP Regular Contributor
I just added 10 parameters with no issue.  The last 6 params shown below, the first 4 are visible when scrolling up in the dialog box.  We might be able to assist further if you provide a little more info on how you're trying to add the parameters and confirm what type of toolbox you are using (normal ".tbx" v. python ".pyt" toolbox)?
Luke_Pinner
JacobSnyder
It was a silly mistake...thanks so much for your help!!!
-Jacob
