How to select items Programatically in "jimu/dijit/LayerChooserFromMap"
2839
08-03-2015 05:46 AM
sumitzarkar
I am using "jimu/dijit/LayerChooserFromMap" dijit in Configuration UI to select layers from the map, and extracting layer info(URL, LayerDef, Name etc) and using this info in widget using this.config
How do I show previously selected layers in LayerChooserFromMap, when user reopens the configuration panel to edit the config .
RobertScheitlin__GISP
Sumit,
   I don't see any methods or properties that allow this. Actually I don't see any widgets in WAB that use this dijit besides the Geoprocessing widget. Most widgets use the _BasicLayerChooserFromMap or the FeaturelayerChooserFromMap.
