Buffer polygon intersect error : ArcObject Exception from HRESULT: 0x80040215
3087
07-31-2015 04:06 AM
muthukamatchiganesan
I try the get the plogon area with in buffer polygon area. But its always gives error. My error code is "ArcObject Exception from HRESULT: 0x80040215"
My code is given below :
  // Convert the JSON line to an ArcObjects Polyline
  var missing = Type.Missing;
  IPolyline routePolyline = new PolylineClass();
  foreach (var point in args.RoutePolyline)
  (routePolyline as IPointCollection).AddPoint(
  new PointClass {X = point.X, Y = point.Y, SpatialReference = _webMercator},
  ref missing, ref missing);
   routePolyline.SpatialReference = _webMercator;
  // Buffer it...
  var topologicalOperator = routePolyline as ITopologicalOperator;
  var routeBufferPolygon = topologicalOperator.Buffer(args.BufferDistance) as IPolygon;
  foreach (var layer in layersToArea)
  var layerName = layer.Key;
  var jsonPropertyName = layer.Value;
  // Get the feature class and error out if it's not found
  var fc = Utilities.GetFeatureClass(_mapServer, layerName);
  if (fc == null)
  var errMessage = string.Format("Can't find the feature class for '{0}'.", layerName);
  _logger.LogMessage(ServerLogger.msgType.error, "GetStats", -1000, errMessage);
  return ErrorResponse(errMessage);
  // Setup a spatial filter for intersecting our buffer area
  ISpatialFilter sf = new SpatialFilterClass();
  sf.GeometryField = fc.ShapeFieldName;
  sf.Geometry = routeBufferPolygon;
  sf.SpatialRel = esriSpatialRelEnum.esriSpatialRelIntersects;
  // Find the position of the "SQMI" field in the feature class.
  int nameFieldPosition = fc.FindField("SQMI");
  // Execute the query and iterate through the cursor's results.
  IFeatureCursor resultsFeatureCursor = fc.Search(sf, true);
  IFeature resultsFeature = null;
  double totalArea = 0.0;
  while ((resultsFeature = resultsFeatureCursor.NextFeature()) != null)
  // problem accrued here
  IPolygon clippedResultsGeometry = (IPolygon)
   topologicalOperator.Intersect(resultsFeature.Shape,
   ESRI.ArcGIS.Geometry.esriGeometryDimension.esriGeometry2Dimension);
  //clippedResultsGeometry.Densify(0, 0);  // Densify to maintain curved appearance when converted to JSON.
  // Get statistics.
  IArea area = (IArea)clippedResultsGeometry;
  totalArea += area.Area;
  jsonResult.AddDouble(jsonPropertyName, totalArea);
