ArcGIS Runtime for .NET PopUps
4400
07-24-2015 08:00 AM
MattBryant1
Does anyone have any good sample code for a pop-up for a WPF application built using the ArcGIS Runtime for .NET?  This is noticeably missing in this ArcGIS Runtime Toolkit on Github.
Thanks,  Matt
Message was edited by: Matt Bryant
AnttiKajanus1
Hi Matt,
Depending on your requirements for the popup but please see MapOverlays sample from samples repository:
arcgis-runtime-samples-dotnet/MapOverlays.xaml at master · Esri/arcgis-runtime-samples-dotnet · GitH...
arcgis-runtime-samples-dotnet/MapOverlays.xaml.cs at master · Esri/arcgis-runtime-samples-dotnet · G...
Implementation is very straight forward and if you for example need to edit / show attributes in the popup, put FeatureDataForm in and you are good to go.
AnttiKajanus1
Hi Matt,
RQISystems
These links are broken. Is there a current sample of how to use PopUps or CallOuts in .NET MAUI?
