Tab Theme onstartup maximized
3780
8
07-23-2015 04:59 AM
eduAED
Hi!
Do you know how to start the SideBar Controller already maximized on the startup of the application with the TabTheme?
RobertScheitlin__GISP
edu AED,
   This is not something that is configurable, but it is easy to change a line of code to make this happen.
Open [install dir]\server\apps\[app#]\themes\TabTheme\widgets\SidebarController\Widget.js and on line 66 change this.widgetManager.minimizeWidget(this); to this.widgetManager.maximizeWidget(this);
eduAED
Thanks Robert!!
I also saw this option, but I thought maybe there was some place to configure this.
I have another question, maybe you can help me:
I am creating several widgets, and I can show or hide them from other widgets:
var widgetsConfig = this.appConfig.widgetOnScreen.widgets;
for(var i in widgetsConfig){
   if(widgetsConfig[i].name == "WidgetXXX_name"){
   widgetXXX = widgetsConfig[i];
   break;
this..PanelManager.showPanel(widgetXXX );
This is not working for the TabTheme because the widgets are in Tabs!! Any idea???
edu AED
  Sure here is some code that works:
        var widgetsConfig = this.appConfig.widgetPool.widgets;
        var widgetId;
          if(widgetsConfig.name == "LayerList"){
            widgetId = widgetsConfig.id;
            break;
        var sbc = WidgetManager.getInstance().getWidgetsByName("SidebarController")[0];
        sbc.setOpenedIds([widgetId]);
Glad to help. Now it is your turn to help the community by marking this question as answered. All you have to do is click the "Correct Answer" link (the one with the little green star) on the post that provided the answer for you. If the answer was not provided by one of the responders then you can mark any of the replies that you received as helpful by clicking on the "Actions" menu and choosing "Mark as Helpful"
deleted-user-0W0-oLHxDjCX
New Contributor III
Is it possible to make the sidebarcontroller a resizable widget? Sometimes the name of a layer is too long to read in the sidebarcontroller (especially on TabTheme layout).
Best regards
Ezequias
Ezequias,
   I am not sure about making it resizable but you can adjust the max width in the code by editing the [install dir]\server\apps\[app#]\themes\TabTheme\widgets\SidebarController\Widget.js maxWidth property.
New Contributor III
Dear Robert
I would like to make is resizable like we can see in the AttributeTableWidget and in http://codepen.io/graham_saunders/pen/vrDxf
Sincerely
Ezequias
Ezequias,
   I don't use the tab theme, so I have not had the need to look into that level of work to make that happen. I would suggest you start a new Idea ofr this enhancement and get people to vote it up.
JunshanLiu
Occasional Contributor III
If you set a widget in widget pool as openAtStart, the tab theme should be opened as maximized, but there is a bug in the current version so the sidebar controller can't be opened. This bug will be fixed in developer edition 1.2 release.
