Find path upstream with weight in geometric network (ArcGIS)
2814
07-22-2015 07:52 PM
ĐứcTrần_Ngọc1
Hi everyone, I have an issue about using weight in geometric network in ArcGIS Desktop. In the example below, I have a simple network with a source & some junctions. And it has a loop through B-C-D-E-F. I'm trying to use the Find Path Upstream function to find the path from junction A to the source, i've created a weight based on the length of the edge feature, but it seem doesn't work. Can anyone tell me or show me:
  • How can I set up a weight to Find Path Upstream from point A to the source through the shortest path (which means A-B-C-D-E-Source in this case)?
  • Which weight should I use & how can I do it if I want to find path from A to F to Source?
Thank you very much for your helping
