How to access file geodatabase(.gdb extension) created from Arc Map in ArcGIS Runtime Qt 10.2.6.
8254
10
07-16-2015 08:14 PM
Bhargav_KumarK
I created file geodatabase in Arc Map consisting of feature classes. These feature classes I want to access in ArcGIS Qt Runtime and see in application.
Bhargav_KumarK
There is function EsriRuntimeQt::WorkspaceInfo::CreateFileGeoDatabaseConnection in ArcGis Qt Runtime, is this related to file geodatabase?
LucasDanzinger
Esri Frequent Contributor
Yes, that static method should allow you to connect to a file geodatabase. You will need to use this in conjunction with Local Server in C++. I recommend you take a look at the Local Server > Shapefile sample and base your code off that.
Luke
Bhargav_KumarK
I tried using this static method but not able to access layers present in file geodatabase(*.gdb). Can you please  give more  insight on how to achieve this in Qt SDK and also if possible any code snippets.
Thanks,Bhargav
ThomasDunn
Bhargav, I have a couple of questions for you:
  • Are you planning to only read the file GDB?
  • Do you receive any messages when you try to read from the file geodatabase?
Thank you.
Bhargav_KumarK
1. I am planning to read only file geodatabase, editing is not required.
2. When I tried using  EsriRuntimeQt::WorkspaceInfo::CreateFileGeoDatabaseConnection, where to give layers name  to load.
ThomasDunn
WRT
What messages did you receive?
Bhargav_KumarK
I used like this in my code..
  try
    // You can't modify the dynamic workspaces on a running local map service.
    m_localMapService.stopAndWait();
    // get dynamic workspaces from service
    EsriRuntimeQt::WorkspaceInfoSet& workspaceInfoSet = m_localMapService.dynamicWorkspaces();
    // create a workspace info via the static method according to data type
    // e.g. shapefile folder connection
    //EsriRuntimeQt::WorkspaceInfo workspaceInfo = EsriRuntimeQt::WorkspaceInfo::CreateShapefileFolderConnection(m_workspaceId, fileDir);//shapefile
    EsriRuntimeQt::WorkspaceInfo workspaceInfo = EsriRuntimeQt::WorkspaceInfo::CreateFileGeoDatabaseConnection(m_workspaceId, "/home/sau/Downloads/Sample.gdb");
    workspaceInfo.setEditable(true);
    // set dynamic workspaces for our local map service
    workspaceInfoSet.add(workspaceInfo);
    m_localMapService.start();
  catch (EsriRuntimeQt::Exception ex)
    QMessageBox::warning(this, "Error", ex.what(), QMessageBox::Ok);
I am not getting messages for this part of code. When m_localMapService.start() is called onLocalServiceCreationSuccess() slot is called.
void ShapeFile::onLocalServiceCreationSuccess(const QString& url, const QString& name)
  Q_UNUSED(url);
  Q_UNUSED(name);
//   // create the ArcGISDynamicMapServiceLayer using the LocalMapService's url
//   m_dynamicLocalServiceLayer = new EsriRuntimeQt::ArcGISDynamicMapServiceLayer(m_localMapService.urlMapService(), this);
//   m_map->addLayer(m_dynamicLocalServiceLayer);
    m_dynamicLayer = new EsriRuntimeQt::ArcGISDynamicMapServiceLayer(m_localMapService.urlMapService(), this);
    connect(m_dynamicLayer, SIGNAL(layerCreateComplete()), this, SLOT(onLayerCreateComplete()));
    connect(m_dynamicLayer, SIGNAL(layerCreateError(QString)), this, SLOT(onLayerCreateError(QString)));
    m_map->addLayer(m_dynamicLayer);
on dynamic layer creation onLayerCreateComplete() slot called.
void ShapeFile::onLayerCreateComplete()
  m_dynamicLayer->setVisible(true);
  EsriRuntimeQt::DynamicLayerInfoCollection& layerInfos = m_dynamicLayer->dynamicLayerInfos();
  EsriRuntimeQt::DynamicLayerInfo* layerInfo = layerInfos[0];
  if (!layerInfo)
    return;
  /* Apply a renderer for vector layers.
   * Note: It is always necessary to provide a renderer, but the renderer provided does
   * not need to be valid with regard to the actual layer and geometry type, it simply
   * needs to be a valid renderer. If the renderer specified here is not appropriate for
   * the geometry type of the layer the symbology will fall back to a default
   * SimpleMarkerSymbol, SimpleLineSymbol or SimpleFillSymbol.
  EsriRuntimeQt::SimpleRenderer* simpleRenderer;
  //simpleRenderer = new EsriRuntimeQt::SimpleRenderer(EsriRuntimeQt::SimpleLineSymbol(QColor(1, 1, 1), 6.0), this);//0, 100, 250
  simpleRenderer = new EsriRuntimeQt::SimpleRenderer(EsriRuntimeQt::SimpleMarkerSymbol(Qt::blue, 16, EsriRuntimeQt::SimpleMarkerSymbolStyle::Diamond));
  EsriRuntimeQt::DrawingInfo* drawingInfo = new EsriRuntimeQt::DrawingInfo(simpleRenderer, 20, this);
  layerInfo->setDrawingInfo(drawingInfo);
  // Create the table data source
  EsriRuntimeQt::TableDataSource* dataSource = new EsriRuntimeQt::TableDataSource(this);
  dataSource->setWorkspaceId(m_workspaceId);
  dataSource->setDataSourceName("Cities");
  qDebug() << "DataSource JSON" << dataSource->toJson();
  // Set the data source
  EsriRuntimeQt::LayerDataSource* layerDataSource = new EsriRuntimeQt::LayerDataSource(this);
  layerDataSource->setDataSource(dataSource);
  layerInfo->setLayerSource(layerDataSource);
  m_dynamicLayer->refresh();
ThomasDunn
Bhargav,
To access a file geodatabase, you must use local server. As an alternative, you can move your to a Runtime geodatabase authored in ArcMap. There are many advantages of Runtime geodatabases over file geodatabases in the context of a Runtime SDK app. Here are a few.
  • Access does not require local server.
  • Code for accessing a geodatabase can be written in C++ or QML. You can use QML to write apps that across the five platforms that QML supports.
  • Runtime geodatabase maintains feature symbology, which can be overridden by your app.
  • The code becomes simpler.
To access a Runtime geodatabase with the SDK:
  1. Create a Geodatabase object that references the Runtime geodatabase file.
  2. Create GeodatabaseFeatureTable that references a feature class in the Geodatabase object.
  3. Create a FeatureLayer object and set its feature table to the GeodatabaseFeatureTable object.
  4. Add the FeatureLayer to your Map object.
Where does the Runtime geodatabase come from?
  • You create it using ArcMap. To see how to do this, read Creating ArcGIS Runtime content​.
  • You can script it using the geoprocessing tool available in ArcToolbox at Data Management > Packages > Create Runtime Content. The script can be reused to update your Runtime geodatabase from the file geodatabase if that is necessary.
Bhargav_KumarK
Thank you. I have idea of accessing runtime geodatabase from Qt Application. How to access a file geodatabase( *.gdb) using local server, can you give some more idea how to achieve this?
Regards,
Bhargav
