Statistics NOT working in ArcGIS Online.
3728
07-14-2015 07:35 AM
MikeLiska
Can someone help me with figuring out why the statistics are not correctly displaying in ArcGIS Online?  I have tried calling ESRI support without any help from them.  In ArcMap the statistics are correct but when using them in Online it is multiplying everything by 6.
NilsBabel
Did you ever find an answer to this?  I just noticed the same thing.  I have a feature service hosted locally with ArcGIS Server.  When I look at the statistics they are incorrect.  The 'number of values' may be the culprit.  Seems like this should be the same as the number of features in the layer but it is quite a bit higher.  This is a pretty serious bug.  It trickles down to Ops Dashboard widgets.
