"Nested" or "Cascading" filtering
6568
07-13-2015 12:49 AM
Lars_ElmkærChwastek
Is it possible with the standard query tool to create Nested or Cascading filtering? Or du you have to create your own widget for that? And by Nested/Cascading I mean, selecting for instance the state in the first query box and then being shown only the cities within that state in the next query box.
RobertScheitlin__GISP
Lars,
   No nested queries are NOT supported by the Query widget, That type of functionality will require you to develop a custom widget.
Lars,
Lars_ElmkærChwastek
Hi Robert,
Thank you for your fast reply. Do you by any chance know of a sample code anywhere on Geonet?
Lars,
  I don't have a WAB widget example but here is a JS API sample.
<!DOCTYPE html>
<html>
<head>
  <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" />
  <title>Drop Down Test</title>
  <link rel="stylesheet" href="http://js.arcgis.com/3.13/dijit/themes/claro/claro.css">
  <link rel="stylesheet" href="http://js.arcgis.com/3.13/dojo/resources/dojo.css">
  <link rel="stylesheet" href="http://js.arcgis.com/3.13/esri/css/esri.css">
  <script src="http://js.arcgis.com/3.13/"></script>
  <style>
    html,
    body,
    #mainWindow {
      height: 100%;
      width: 100%;
      margin: 0;
      padding: 0;
    body {
      background-color: #FFF;
      overflow: hidden;
      font-family: "Trebuchet MS";
    #header {
      height: 3%;
      overflow: auto;
  </style>
  <script>
    var map;
    require([
      "esri/map",
      "dojo/on",
      "esri/tasks/query",
      "esri/layers/FeatureLayer",
      "dojo/store/Memory",
      "dojo/_base/array",
      "dojo/_base/lang",
      "esri/request",
      "dojo/json",
      "dojo/parser",
      "dijit/layout/BorderContainer",
      "dijit/layout/ContentPane",
      "dijit/form/Button",
      "dijit/form/ComboBox",
      "dojo/domReady!"
    ], function(
      Map, on, Query, FeatureLayer, Memory, array, lang, esriRequest, json, parser
      parser.parse();
      map = new Map("map", {
        basemap: "topo",
        center: [-98.1883, 37.0868],
        zoom: 5
      esriRequest({
        url: 'http://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/3/query?where=1%3D1&outF...',
        content:{
          f:'json'
        handleAs:'json',
        callbackParamName:'callback',
        timeout:15000
      }).then(lang.hitch(this,function(response){
        var store2 = new Memory({data:[]});
        dijit.byId("stateSelect").set('store',store2);
        var data = array.map(response.features,lang.hitch(this,function(feat, index){
          var name = feat.attributes.STATE_NAME;
          var value = feat.attributes.STATE_NAME;
          var dataItem = {
            value:value
          return dataItem;
        store2 = new Memory({data:data});
      var States = new FeatureLayer("http://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/3", {
        mode: FeatureLayer.MODE_SELECTION,
        outFields: ["*"]
      var Counties = new FeatureLayer("http://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/2", {
        outFields: ["*"]
      map.addLayers([States,Counties]);
      app = {
        zoomRow: function(id, which){
          States.clearSelection();
          Counties.clearSelection();
          var query = new Query();
          var thePoly, theExtent;
          if(which == "State"){
            query.where = "STATE_NAME='" + (id).toString() + "'";
            console.info(query.where);
            query.returnGeometry = true;
            States.selectFeatures(query, FeatureLayer.SELECTION_NEW, function (features) {
              thePoly = features[0].geometry;
              theExtent = thePoly.getExtent().expand(2); //Zoom out slightly from the polygon's extent
              map.setExtent(theExtent);
            esriRequest({
              url: "http://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/2/query?where=STATE_NAME...'" + id.toString() + "'&outFields=NAME&returnGeometry=false&orderByFields=NAME&returnDistinctValues=true&f=json",
              content:{
                f:'json'
              handleAs:'json',
              timeout:15000
              dijit.byId("countySelect").set('store',store2);
                var name = feat.attributes.NAME;
                var dataItem = {
                return dataItem;
              document.getElementById('countySelect').value = "Select County";
          }else if(which == "County"){
            var county = (id).toString();
            county = county.replace(" County", "");
            query.where = "NAME='" + county + "'";
            Counties.selectFeatures(query, FeatureLayer.SELECTION_NEW, function (features) {
  </script>
</head>
<body class="claro">
  <div id="mainWindow" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline', gutters:false" style="padding:0px;margin:0px;">
    <div id="header" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'top'" style="overflow:hidden;border:none;border-bottom: 3px solid #CC9900;font-family: Windows;font-size:14pt; color: #FFFFFF;background: #000000; "> Select a State/County and zoom to it on the map:
      <input id="stateSelect" data-dojo-type="dijit/form/ComboBox" value="Select State" onchange="app.zoomRow(document.getElementById('stateSelect').value, 'State');" data-dojo-props="maxHeight: 200" />
      <input id="countySelect" data-dojo-type="dijit/form/ComboBox" value="Select County" onchange="app.zoomRow(document.getElementById('countySelect').value, 'County');" />
      <input type="hidden" name="stateabbr" id="stateabbr" />
    </div>
    <div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'left'" style="width:100%;height:95%;border:none;padding:0px;margin:0px;"></div>
  </div>
</body>
</html>
MichaelRobb
Honored Contributor
Did you happen to migrate JS code to a widget for Web app builder to utilize nested Queries in WAB?
