Editing shapefile via Runtime .NET SDK
3846
07-13-2015 04:36 AM
SzymonPiskula
Hi
I try to add a new feature to a shapefile using the following test code but i get:
'SQL error or missing database' error.
I tried populating FID field but that does not help.  The source shapefile loads and draws OK on the map. Also i checked and it is not set to read-only. Is it possible at all to edit directly shape files using the SDK? What would be the correct way of doing it?
Szymon
Tags (3)
MichaelBranscomb
Esri Frequent Contributor
Shapefiles are currently read-only, this should be reflected in the value of the ShapefileTable.IsReadOnly property. In a future release we would like to make Shapefiles editable but the mobile geodatabase will obviously remain the recommended route for editing data.
Cheers
Mike
