Using ArcGIS for server maps instead arcgis.com maps
4644
07-09-2015 01:04 AM
MohammadShahheydari1
Hi
How can I use my ArcGIS for server maps instead arcgis.com maps
JenniferMcCall4
Occasional Contributor III
Hi Mohammad,
I'm assuming you're referring to using an ArcGIS Server map service in the ArcGIS Online map viewer for your web map instead of the basemaps provided there.
If this a map service you are hosting on your own server, see the following steps:
1. Click ​Add​, and choose ​Add Layer from Web
2. In the first drop down, ensure An ArcGIS Server Web Service is chosen.  In the URL section, enter the rest endpoint for your map service.
3. Ensure you check the box beside "Use as Basemap"
You can also refer Choose basemap—ArcGIS Online Help | ArcGIS for more information, and instructions on how to change the basemap from searchable layers on ArcGIS Online.
Jenn
Hi jeniifer
Thank you very much for your answer.
RobertScheitlin__GISP
Mohammed,
   Jennifer's advice is spot on if you were not aware of that already. The other option is to use the Local Layer widget LocalLayerWidget and AccessifizrWidget this allows you to add layers from your own ArcGIS Server right into WAB from the WAB UI. There is still an unfortunate need to initially have a webmap as a begining point and then the Local Layer widget can completely replace the contents of the initial webmap or just add to it.
