WMS with Authentication
5701
07-09-2015 08:11 AM
MarvinKalani
I want to connect to a WMS Rest Service with a Basic Authentication but can not because I can not set the user credentials to access it.
When will this be possible? It seems that it was possible with WPF or Silverlight.
Greetings
Marvin
JustinRodriguez
Hello Marvin,
I hope you are doing well. WMS should be compatible with Basic Authentication. Here is an article that explains it pretty well:
ArcGIS Help (10.2, 10.2.1, and 10.2.2)
I hope that helps.
Justin
Esri Support
MarvinKalani
Hi Justin,
thanks for the fast answer, but your link has no article.
I am trying to connect a client via the SDK and C# by defining a WMS Layer programmatically. Like :
var uri = new Uri(uristring);
var wmsLayer = new WmsLayer(uri);
await wmsLayer.InitializeAsync();
Map.Layers.Add(wmsLayer);
The missing part is the part to define the credentials, but actually there is no :
wmsLayer.Usercredentials ... or wmsLayer.Username, wmsLayer.Password
best regards,
Marvin
JesperBlom
Hi
I have the same problem. Can´t find any Credentials property in the Esri.ArcGISRuntime.Layers.WmsLayer class in the ArcGis API for .NET. I have used wmsLayer in the API for WPF and there it can be found in the class ESRI.ArcGIS.Client.Toolkit.DataSources.WmsLayer.
Regards
Jesper
