HTML rendering in a column in a dgrid
4920
07-06-2015 09:51 PM
AndrewTerwiel
Does anyone know how I can get html to render in a dgrid column?
This is what I'm trying to do:
var linksData = [
                { link: '<span class="glyphicon glyphicon-info-sign"></span> DP Plans' },
                { link: 'T1 Land' },
                { link: 'T1 Property' }
            var linksGrid = new Grid({
                showHeader: false,
                className: "dgrid-autoheight",
                columns: {
                    link: 'link'
  linksGrid.renderArray(linksData);
The result of this code is that I see the literal string in the first row's column. I'd like the html to be rendered by the browser.
AndrewTerwiel
Thanks, Robert. You put me on the right track. I ended up using the formatter function like so:
var linksData = [
                { link: '<span class="glyphicon glyphicon-circle-arrow-right"></span> DP Plans' },
                { link: '<span class="glyphicon glyphicon-circle-arrow-right"></span> T1 Land' },
                { link: '<span class="glyphicon glyphicon-circle-arrow-right"></span> T1 Property' }
                showHeader: false,
                columns: {
                    link: {
                        label: 'link',
                        formatter: function (item) {
                            return item;
This has made the browser render the span element correctly so that I get a nice little icon next to my link text.
RobertScheitlin__GISP
Andrew,
   You are going to have to use a renderCell function for your first column. I have never used renderArray so I am not sure how that works in with renderCell but here is a link you can refer to:
javascript - renderCell function not being called? - Stack Overflow
AndrewTerwiel
var linksData = [
                showHeader: false,
                columns: {
                    link: {
                        label: 'link',
                            return item;
