setup a map
3266
06-28-2015 09:41 AM
LouisGuadagno
how do you get started I cant find a map in my files when I start a new project I have maps saved in my projects in Pro
XanderBakker
Esri Esteemed Contributor
Operations Dashboard works with a web map published on ArcGIS Online or Portal. You should publish the content you have in ArcGIS Pro to ArcGIS Online (or Portal) Share a web map—ArcGIS Pro | ArcGIS for Professionals , create a webmap Create a map—Operations Dashboard for ArcGIS | ArcGIS  and then you can Create an operation view—Operations Dashboard for ArcGIS | ArcGIS
