Why is my summary widget in Operations Dashboard NOT providing the correct sum?
6467
07-13-2015 06:00 PM
MikeLiska
Why does my summary widget in Operations Dashboard not providing me with the correct sum of my data.  I am trying to summarized the total centerline miles and lane miles in my data based on the entire network of streets and also from a queried result.  My data is calculating correct in ArcMap but not in Operations Dashboard.  Can someone tell me why or how I can fix it?
Mike
JayChen
Hi Mike,
Can you give a bit more details on this issue? So summary widget doesn't work in both cases (total centerline/lane miles from entire network, and from a queried result)? It's probably easier to trouble-shoot the issue with your data. Is it possible to share your view with me?
-Jay
MikeLiska
Hi Jay,
I have found that when I run my statistics in any ArcGIS Online Web Map or Web App they all are being multiplied by 6. When I click on the data and view it in a pop up window or in a table format the data is correct. Only when I run the Statistics on it is when it does not show correctly. So when I run a query on my data using Operations Dashboard and have it return a summary of the queried results, everything is multiplied by 6. When I run statistics on the same feature layer and feature service in ArcMap my results are correct. Only in ArcGIS Online is it not working.
--Mike
<http://www.hrgreen.com/index.aspx>MICHAEL LISKA, GISP
Project GIS Specialist I
HR GREEN, INC.
<http://www.linkedin.com/company/hr-green-inc.?trk=hb_tab_compy_id_40620> <https://www.facebook.com/HRGreenInc> <http://www.twitter.com/hrgreen1> <https://plus.google.com/u/0/110913870783556851676/about> <http://www.youtube.com/user/HRGreenInc>
The contents of this transmission and any attachments are confidential and intended for the use of the individual or entity to which it is addressed. If the reader of this message is not the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is prohibited.
