GeoEvent Processor: Event Volume Control gives errors (StackTraceElement)
4201
06-26-2015 01:26 AM
ThibautDelaere1
I'm using the Event Volume Control Processor in GeoEvent Extension 10.3.1 to limit the amount of data from a input web socket.
Although the EVC Processor seems to work, but the log is flooded with errors: [Ljava.lang.StackTraceElement;@<some id>
I did set the logging to the highest level for the EVCProcessor, but I'm not getting any more information about the errors.
Does anybody know what's causing these errors?
Regards,
Thibaut
PatrickHill1
Thibaut,
I have been testing this out and I am not able to replicate. I have a very simple test for this, however, I wonder if there is something specific to your service or geoevent definitions causing the error. Would it be possible for you to send me a config file of your service? I may be able to replicate the error if I have things set up more closely to how you are working with the service.
Thanks -Patrick
ThibautDelaere1
Patrick,
I placed the configuration of the geoevent definition here: https://siggisnv-my.sharepoint.com/personal/thibaut_delaere_siggis_be/Documents/Shared%20with%20Ever...
It would be very much appreciated if you could take a look at it.
Thibaut
ThibautDelaere1
Hi Patrick,
Do you have by any chance a deployed version of the Event Volume Control Processor for ArcGIS 10.3.1?
Maybe something is wrong with my version.
Thanks in advance,
Thibaut
