Failed Query from Joined Table with Query Widget (Developer Edition)
6620
9
06-24-2015 08:21 AM
MalcolmEchaluce
I have a standalone table joined with a feature layer.  I have set up a query from one of the fields of that joined standalone table but the query fails.  Does it not allow for it to return queries from joined tables?  I have the configuration in the config_Query.json similar to the other queries, except all other queries are feature layers without a join.  Below is the config for the particular query from the feature layer with the joined table.  Please ignore the "............" in place of the urls.
      "name": "Search by Case Status",
      "url": "http://....................rest/25",
      "infoWindowTemplate":"<b>${VECTOR.PLAN_PENDING.NAME}</b><hr><b>Case Number</b>: <a target='_blank' href='http://egcap.........../${VECTOR.PLAN_PENDING.CASE_}'>${VECTOR.PLAN_PENDING.CASE_}</a><br><b>Case Type:</b> ${VECTOR.PLAN_PENDING.CASETYPE}<br><b>Case Status:</b> ${gisdb.vector.pending_plan_data.status}<br><b>Staff Report:</b><a target ='_blank' href='${VECTOR.PLAN_PENDING.CASELINK}'>Click Here</a><br><b>Acreage:</b> ${VECTOR.PLAN_PENDING.ACREAGE}<br><b>Planner:</b> ${gisdb.vector.pending_plan_data.pln_case_planner}<br><br><a href='mailto:${gisdb.vector.pending_plan_data.mail}?subject=Question%20about%20case%20${VECTOR.PLAN_PENDING.CASE_} '>Email Planner</a>",
   "filter": {
        "logicalOperator": "AND",
        "parts": [
            "fieldObj": {
              "name": "gisdb.vector.pending_plan_data.status",
              "label": "gisdb.vector.pending_plan_data.status",
              "shortType": "string",
              "type": "esriFieldTypeString"
            "operator": "stringOperatorIs",
            "valueObj": {
              "isValid": true,
              "type": "unique",
              "value": "Accepted"
            "interactiveObj": {
              "prompt": "Case Status",
              "hint": "Enter Case Status"
            "caseSensitive": false,
            "expr": "gisdb.vector.pending_plan_data.status = 'Accepted'"
      "popup": {
        "title": "${VECTOR.PLAN_PENDING.NAME}",
        "fields": [
            "name": "VECTOR.PLAN_PENDING.NAME",
            "type": "esriFieldTypeString",
            "alias": "NAME",
            "length": 39,
            "domain": null,
            "specialType": "none",
            "visibility": false,
            "showInInfoWindow": false
            "name": "VECTOR.PLAN_PENDING.CASE_",
            "alias": "Case Number",
            "length": 13,
            "domain": null,
            "showInInfoWindow": true
            "name": "VECTOR.PLAN_PENDING.CASETYPE",
            "alias": "Case Type",
            "length": 13,
            "domain": null,
            "alias": "Case Status",
            "length": 13,
            "domain": null,
            "name": "VECTOR.PLAN_PENDING.CASELINK",
            "type": "esrifieldtypestring",
            "alias": "Staff Report",
  "length": 255,
            "domain": null,
            "specialType": "link",
            "name": "VECTOR.PLAN_PENDING.ACREAGE",
            "alias": "Acreage",
            "length": 13,
            "domain": null,
            "name": "gisdb.vector.pending_plan_data.pln_case_planner",
            "alias": "Planner",
            "length": 13,
            "domain": null,
            "name": "gisdb.vector.pending_plan_data.mail",
            "alias": "Email",
  "length": 13,
            "domain": null,
      "resultsSymbol": {
        "color": [
          155,
          187,
          89,
          128
        "outline": {
          "color": [
            115,
            140,
            61,
            255
          "width": 1.5,
          "type": "esriSLS",
          "style": "esriSLSSolid"
        "type": "esriSFS",
        "style": "esriSFSSolid"
      "objectIdField": "VECTOR.PLAN_PENDING.OBJECTID"
RobertScheitlin__GISP
Malcolm,
   What does the web console report as far as any errors?
MalcolmEchaluce
Robert,
The error from the web console is below.  My apologies for not having anything beyond this.  I'm stumped.
Error: Failed to execute query.
    at Error (native)
    at Object.h.load (http://js.arcgis.com/3.13/init.js:897:343)
    at http://js.arcgis.com/3.13/init.js:191:69
    at c (http://js.arcgis.com/3.13/init.js:76:221)
    at d (http://js.arcgis.com/3.13/init.js:76:10)
    at b.Deferred.resolve.callback (http://js.arcgis.com/3.13/init.js:77:350)
    at c (http://js.arcgis.com/3.13/init.js:76:436)
    at http://js.arcgis.com/3.13/init.js:195:300x @ init.js:192(anonymous function) @ init.js:191c @ init.js:76d @ init.js:76b.Deferred.resolve.callback @ init.js:77c @ init.js:76d @ init.js:76b.Deferred.resolve.callback @ init.js:77c @ init.js:76d @ init.js:76b.Deferred.resolve.callback @ init.js:77c @ init.js:76d @ init.js:76b.Deferred.resolve.callback @ init.js:77(anonymous function) @ init.js:195k @ init.js:199m @ init.js:199f.resolve @ init.js:201a @ init.js:200k @ init.js:200m @ init.js:199f.resolve @ init.js:201a @ init.js:200k @ init.js:200m @ init.js:199f.resolve @ init.js:201a @ init.js:200k @ init.js:200m @ init.js:199f.resolve @ init.js:201q @ init.js:160f @ init.js:164
Widget.js:751 Error: Failed to execute query.
    at Error (native)
Malcolm,
   I am throwing together a joined service for testing and will let you know the results.
Malcolm,
   So based on my testing joined data is not the issue. My recommendation is to remove some fields until you can get the query to work.
MalcolmEchaluce
Are you referring to fields in my data or the fields in the pop-up configuration from the code snippet I provided? Unfortunately, I'm not going to be able to remove fields from the data itself.
Malcolm,
   No I am talking about removing fields from the Query widgets json (not the actual data).
JakeSkinner
Esri Esteemed Contributor
Hi Malcolm,
I'm running into the same issue with a CSV joined to a File Geodatabase feature class.  I found the following bug:
BUG-000086777 - The Query widget in Web AppBuilder generates a "Qu..
Robert Scheitlin, what type of feature class/table are you using for the join?
Jake,
   I am using a standard SDE table.
JakeSkinner
Looks like this bug isn't an issue if both the feature class and table reside in the same geodatabase.  I imported the CSV file I am using into the same File Geodatabase as my feature class, and I am now able to query on the joined records.
