hosted home button
4292
7
06-23-2015 08:43 AM
BrianLomas
My home button doesn't change the map at all when clicked. I'm using an AGOL hosted swipe map. Anybody know how to change this for a AGOL hosted map?
Tags (1)
MarkCooney
Okay, we are able to reproduce, and have identified this as a bug with the home button with web maps using a projection other than Web Mercator.  We will try to find a fix and include on the next release.
GregoryL_Azou
The home button should allows to get back to the location that was initially used when the app opened. So until you navigate the map, the expected behavior is that the home button won't do anything.
Can you share a link to your application?
BrianLomas
It's currently only shared within the organization, I cannot change this due to our admin's restrictions... The home button doesn't change the map even after you pan and zoom to a totally different location.
GregoryL_Azou
Ok sorry about this. If you can answer a couple of questions, we should be able to reproduce and fix:
- are you using swipe or spyglass?
- have you enabled or disabled any settings? (popup, swipe series)
- what browser are you using?
BrianLomas
We are using swipe.
The only setting disabled is 'swipe series'
I am using Firefox 38.0.5 but I get the same results on IE 11.0.20
Thanks for your help on this.
MarkCooney
I am unfortunately unable to reproduce on either Firefox or IE.  A few more questions for you to try and reproduce on our end:
  • Are you swiping layers from one map, or swiping two maps?
  • What projection are your map(s) in?
  • What OS are you on?
BrianLomas
1.) Originally I was swiping two maps then switched to one trying to fix the problem but it didn't make a difference.
2.) Projection: Transverse Mercator
3.) OS: Windows 7
MarkCooney
